** S2000 TURBO KIT FOR SALE ** Turbonetics
Old Aug 31, 2007 | 01:04 PM
sportridermike's Avatar
Default ** S2000 TURBO KIT FOR SALE ** Turbonetics
FOR SALE: Custom designed turbocharger kit for S2000
I can't get images posted, so see pics at S2Ki for sale forum:
http://www.s2ki.com/forums/ind...20818
This kit was designed by a Turbonetics engineer for a project car, so most of the components are Turbonetics / Spearco, and the tubing was built by Turbonetics' welders/fabricators. Here are the details:
Turbonetics T3/T4 ball bearing turbo
(60-1 HiFi / Stage 5 / 0.63 AR / water cooled)
Turbonetics Evolution wastegate
Turbonetics Raptor blow-off valve BOV
Spearco air-to-air front mount intercooler A2A FMIC
Rev Hard cast iron manifold
(with high temp black 1800'F coating)
RC engineering 550cc injectors
(complete with required spacers & pigtail connectors)
Custom designed aluminum airbox
(shields air filter from engine heat & draws cold air from fenderwell)
Perma-cool oil filter relocation kit
(necessary, as turbo sits right where factory oil filter usually is)
Custom designed stainless downpipe
(with high temp black 1200'F coating + heat wrap)
Custom designed steel intercooler tubing
(painted with a textured metallic aluminum paint)
Turbonetics silicone connector hoses & clamps
Misc hoses & clamps (oil supply / oil drain / coolant / vacuum)
Everything has been cleaned, sandblasted and repainted. The turbo, wastegate & blow-off valve have been inspected and/or rebuilt by Turbonetics, so they're nearly new again. The ball bearing turbo is worth nearly $1600 brand new MSRP.
Kit is 95% complete (missing fuel pump, misc nuts/bolts). Although this kit should bolt-on to any 2000-2003 S2K (and probably 2004+, but not sure), it will require a certain amount of mechanical (and turbocharged vehicle) knowledge to piece together & install (since it was a custom kit built for a project car, there are no install instructions or step-by-step pictures).
Asking $3800 for everything listed above
Plus (if interested) $700 for AEM EMS, already tuned for this setup
(EMS alone is roughly $1000, and dyno time for tuning ran up to $500)
Mike, sportridermike@hotmail.com
simi valley, ca
