'90 CRX Si (1.6L) Error code...
Old Aug 31, 2007 | 10:44 AM
xiona's Avatar
Default '90 CRX Si (1.6L) Error code...
ok so i was driving along and BAM distributor siezed up. at first i thought it was the timing belt and didnt feel like screwing with it so i brought it somewhere to have them do it. they found the siezed dizzy and replaced it and the timing belt i gave them as well.
the car had been working mint prior, now the check engine light is on and popping a code 9, "a problem with the CYL circuit of the TDC/CRANK/CYL sensor". it gives me a hesitation buck when i start off and go from 1600 > 2000 RPM. when its idling its not bad but you can tell something is a little rough.
anyways i just needed some input incase someone else happened to go through this same issue. plus i need to know what to tell the douche to do because he is seriously lazy. thanks in advance
Old Aug 31, 2007 | 02:09 PM
rustbucketrex's Avatar
Default Re: '90 CRX Si (1.6L) Error code... (xiona)
Make sure that the dist. is for an SI not a DX. It should be a TD-02U.
Quiks66
Mar 5, 2008 04:32 PM
xiona
Sep 1, 2007 09:15 PM
Iron_Forrix
May 4, 2007 12:14 PM
SPORT INJECTION
22
May 30, 2006 04:15 PM
South Bay Surfer
Feb 23, 2004 10:01 AM
