max hp stock injectors all motor
Old Jun 14, 2002 | 04:13 PM
DLB1994's Avatar
Default max hp stock injectors all motor
setup is
ls/vtec
pr3 pistons
stock ls rods
milled 10ths b16a head
crower stage 2 cams
crower Dual valve spring&retainers
aem fuel rail
B&M fuel rail
skunk2 intake manifold
aem cam gears
full 2 1/4 exhust
jdm 4-1 header
cold air intake
p28 ecu reprogramed
high psi fuel pump
Reid's Avatar
Global Moderator
Default Re: max hp stock injectors all motor (DLB1994)
What are you asking?
Old Jun 14, 2002 | 04:15 PM
DLB1994's Avatar
Default Re: max hp stock injectors all motor (Reid)
whats the max whp i can make all motor with the stock injectors
Old Jun 14, 2002 | 04:16 PM
Reid's Avatar
Global Moderator
How many tenths was your head milled?
Old Jun 14, 2002 | 04:24 PM
DLB1994's Avatar
just 10 thousands
Old Jun 14, 2002 | 07:06 PM
Padawan's Avatar
Darth ModerVader
It's not really a question of max horsepower. The injectors will either be able or unable to reliably support the setup at the ideal A/F ratio.
AccordBOB381
Aug 16, 2014 07:37 AM
SickIntegraWon
11
May 9, 2007 08:20 PM
slow_ls
11
Jan 16, 2007 08:46 PM
haggar
Aug 1, 2003 11:29 AM
DLB1994
Jun 15, 2002 12:01 PM
