Mileage...Poll
I have an '04 Accord EX sedan 4 cyl. I currently have 70,000 miles on it. I wanted to take a poll and see how many miles other people have on their '04 Accords, if it is above 70K...Also, can you tell me what if any kinds of problems you have had with it in those miles?
Thanks.
Thanks.
94 accord lx 148k. Replaced radiator last year and both axles. That was it other than brakes and a few exhaust systems front to back. I tottaled it last month-RIP. I was the original owner and I'll miss the car.
93 honda accord se 172k still kicking w/solid 28 mpg when its not throwing a code 43? since I got it from my sister @156k last year have done (original owner)
famous rust spot repair over dr side rear wheel well
changed all rotors/pads
changed radiator/ all hoses
dist cap/rotor
plugs
plug wires
valve cover gaket
master cylinder
gas filter
air filter
replaced exhaust front to back
4 new tiresw/alignment
changed oil 3 times and I fully expect to get another 100k on oil/air filter changes!!
dist cap/rotor
plugs
plug wires
valve cover gaket
master cylinder
gas filter
air filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 hoopdy »</TD></TR><TR><TD CLASS="quote">...famous rust spot repair over dr side rear wheel well...</TD></TR></TABLE>
Gotta love those infamous rust spots over the rear wheel well
I have the same thing
I have a 95 Accord 2.2L VTEC with 173,XXX miles and still running strong. Just some minor issues that are an easy fix. Want to do a h22 swap within the next year or two though
.I have a 95 Accord 2.2L VTEC with 173,XXX miles and still running strong. Just some minor issues that are an easy fix. Want to do a h22 swap within the next year or two though
Don't have an '04 but do have a '90
with 195k on the clock. Current problems, upper suspension arms on both sides (damn those cheap ebay parts!) front wheel bearing and something wrong with the tie rod on the steering rack and rear brakes are a bit slack. Engine runs perfect and I also have the rear wheel arch rust bits... fun.
i had a 94 accord lx with 149K on it when I sold it this year. my friend has it with 169K on it and this is what was repaired in the last 90K miles
rad cap
exhaust
driver side outer CV joint
A/C recharged 2x
rad cap
exhaust
A/C recharged 2x
1993 Accord SE 201K miles, change oil every 3K or 3 months whatever comes first. - lots of repairs, still kicking, AC still works too!
2006 Accord EXL 19K miles, change oil every 6K miles @ 40% life Honda recommends @ 10%
97 accord lx sedan. With 152k miles. Oil changes every 2,500 miles.
Changed timing belt at 90k.
Replaced axles at 130k.
Need to resurface rotors and replace brakes.
Need a tune up.
Other than that its still running great.
Need a tune up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidcool1977 »</TD></TR><TR><TD CLASS="quote">i thought the OP wanted to know how many miles do ppl with an 04' have on there cars not other year models...</TD></TR></TABLE>
Who cares. He obviously doesn't have a problem with what other people are saying about their non-04 models or else he would have most likely said something.
KCHybrid
Nov 19, 2002 05:12 PM
