91 Accord REPLACE FRONT SIDE MARKER BULB
Old Aug 31, 2007 | 06:58 AM
trimagna's Avatar
Default 91 Accord REPLACE FRONT SIDE MARKER BULB
I need to replace the left side marker bulb on my 91 Accord.
The bulb is not easily accessible from the back.
The lens and holder are connected to a black plastic molding which also holds the headlight.
I tried to remove the corner lens. One screw on the top is accessible but did not help.
I tried to remove the headlight assembly. Two 10mm head screws are accessible from the top bar but there must be more screws somewhere.
What's the best way to replace one silly little bulb in the corner light?
Thanks.
Old Aug 31, 2007 | 03:31 PM
The-Kid's Avatar
Default Re: 91 Accord REPLACE FRONT SIDE MARKER BULB (trimagna)
If its anything like my Accord 5g, you just have to remove that top screw and pull it out. I sometimes use a screw driver as a leverage.
Are you trying to replace the side marker or the corner light next to the headlamp?
You need to remove the bumper to remove the headlight BTW. In anycar, to change those corner bulb, you do not have to remove bumper nor the headlight.
O nice Irvine I live there.
Old Aug 31, 2007 | 07:23 PM
WillEat4F00d's Avatar
Default Re: 91 Accord REPLACE FRONT SIDE MARKER BULB (The-Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Kid &raquo;</TD></TR><TR><TD CLASS="quote">If its anything like my Accord 5g, you just have to remove that top screw and pull it out. I sometimes use a screw driver as a leverage.
O nice Irvine I live there.</TD></TR></TABLE>
I had troubles at first with that. What I didn't do was pull it out hard enough.
Tuuli
Jul 23, 2008 05:04 AM
waggontrainer
Lighting
Jun 5, 2008 03:26 PM
blue_misfit
Dec 4, 2007 09:52 AM
JiGzAcura
Aug 30, 2004 12:00 PM
badassaccord
Sep 26, 2002 05:20 AM
