spark plug gap
Old Aug 31, 2007 | 06:09 AM
rnbguy's Avatar
Default spark plug gap
how do i know if the spark plug gap is too small or too big, im in a turbo d16 ek
(yes i tried to post this in forced induction but it kept saying i must be logged in)
ive made my plug gaps at 0.032 but as for now im only running 5psi and producing a small 90kw atw i dont think i need to shrink the gap that much, is there any way to know, i wanna fix the gap till i get this ecu setup upgraded for bigger performance (5-6 months time)
Old Aug 31, 2007 | 08:47 AM
abnaasefmb's Avatar
Default Re: spark plug gap (rnbguy)
Your post doesn’t ******* belong here, but to answer your question, you want the largest gap possible with out the spark getting blown out. A safe size for if is .030” if it’s cutting under heavy load narrow the gap.
Old Aug 31, 2007 | 06:00 PM
rnbguy's Avatar
Default Re: spark plug gap (abnaasefmb)
thanx but ummmmmmm did you read what i wrote?????
i said i tried to post it in forced induction but the forums script wasnt letting me!
so when u say cutting under heavy load, you mean power is getting killed?
Old Aug 31, 2007 | 06:18 PM
abram_quito's Avatar
the gap for specification is for
Na cars
the gap for FI
should be according to my helms manuals
.032" or lower
hope this has been helpful
Old Aug 31, 2007 | 06:53 PM
rnbguy's Avatar
it has thank you very much, here is a good reading also:
http://www.4strokes.com/tech/sparkplg.asp
http://www.dragstuff.com/techa....html
(although for bikes, helps with cars too)
i wonder if anyone is running 3 step cooler plugs?
Modified by rnbguy at 8:28 PM 8/31/2007
Old Aug 31, 2007 | 09:15 PM
62ndsoldier's Avatar
gap it between .28 and .30, i use .30
Old Sep 1, 2007 | 02:50 AM
abnaasefmb's Avatar
Default Re: (62ndsoldier)
b16 9:1 280hp @ 15lbs on small turbo .032" that's just me though
Old Sep 1, 2007 | 08:21 AM
Db1_77's Avatar
i had my FI setup gapped at .28
there was a 5whp difference between .36 and .28 for me on the dyno.
$.02
-jonathan
Atomic1
May 17, 2010 08:44 PM
josh's ep3
14
Jan 30, 2009 09:57 AM
81CB900C
Aug 16, 2007 09:07 AM
sickofitall1113
Jun 6, 2005 11:48 AM
sylvain
Oct 8, 2004 07:57 AM
