JDM B16A vtec solenoid gasket part # - searched
engine out of an 89 JDM Integra, Part # 15825-P08-005 started leaking the day after installed. Anyone know the correct #? My local Honda deal is no help at all.
For obd0 b16a's use a 90 nsx gasket part# 15825-pr3-005. The earlier solenoids are shaped a little different and require the older gasket. Later one's don't fit well and tear just like your's did. Ive used the nsx gasket on 2 different obd0 b16's with no problems.
http://www.sonsacuraparts.com/...7C008
I was just about to say that the USDM gaskets won't fit the JDM solenoids, believe me I tried. Like mentioned, they're a slightly different shape.
I just got a USDM VTEC solenoid instead, just in case the gasket went out again.
I wasn't aware that the NSX gasket fit. I wish I would of known that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 »</TD></TR><TR><TD CLASS="quote">For obd0 b16a's use a 90 nsx gasket part# 15825-pr3-005. The earlier solenoids are shaped a little different and require the older gasket. Later one's don't fit well and tear just like your's did. Ive used the nsx gasket on 2 different obd0 b16's with no problems.</TD></TR></TABLE>
Very good information. I learned something new today. Honda-Tech FTW!
Furyof4 thanks for the info, turned out I had the right part # but didn't know it was an accura part#. Talked to Len at Sons Accura and will be ordering the part today. Thanks for the link to Sons Accura.
91HATCH
19
Jun 9, 2004 10:25 AM
