car wont start... no power to the starter. HELP?????????
Old Aug 31, 2007 | 03:43 AM
redefsir's Avatar
Default car wont start... no power to the starter. HELP?????????
i have no power to the starter. fuse is good but when i turn the key theres a little click from under the dash. i think the click is a relay but im not sure.
Im not sure if there is a starter relay or not
What can be the problem?
ignition switch?
any help will be much appreciated
Old Aug 31, 2007 | 04:08 AM
EFM_ookie's Avatar
Default Re: car wont start... no power to the starter. HELP????????? (redefsir)
Is your battery good? Have you checked your starter connection? Are all of your grounds hooked up? Did it run before?
Old Aug 31, 2007 | 04:31 AM
redefsir's Avatar
Default Re: car wont start... no power to the starter. HELP????????? (EFM_ookie)
battery is good grounds are good and yes it ran before
Old Aug 31, 2007 | 06:58 AM
redefsir's Avatar
anybody have any ideas?
Old Aug 31, 2007 | 10:09 AM
redefsir's Avatar
nobody????? lil help
Old Aug 31, 2007 | 11:06 AM
redefsir's Avatar
does anyone know if there is a starter relay?
jlicrx's Avatar
if it is manual transmission, it has a starter relay under the dash - also has switch on clutch pedal to keep it from starting without depressing the clutch
Old Aug 31, 2007 | 11:41 AM
redefsir's Avatar
Default Re: car wont start... no power to the starter. HELP????????? (jlicrx)
i hear the click when i press the clutch in so that leads me to beleive the switch is okay.
does anyone one a way to test both the starter relay and the switch on the clutch pedal?
Old Sep 4, 2007 | 04:22 AM
redefsir's Avatar
alright. heres a little update...
changed the relay which wasnt the problem.
after testing a little more the grounds are good!
the weird thing is that if i jump the starter with a wire from the positive terminal on the battery the starter engauges. than after i do that the car will start!.
what could be the problem?
Old Sep 4, 2007 | 05:17 AM
Targa250R's Avatar
be professional
Well, your grounds are apparently good, the main fuse is good, the starter is good, battery is good. There is a break somewhere else in the starter circuit.
I'd check your clutch switch. There is also a chance that the ignition switch contact assembly has a problem, but usually those show up intermittently.
Old Sep 4, 2007 | 05:25 AM
redefsir's Avatar
Default Re: car wont start... no power to the starter. HELP????????? (Targa250R)
i was thinking that too but i'd like to NOT think about that! seems like a head ache....
is the ignition switch seperate from the key tumbler or is it one peice?
Old Sep 4, 2007 | 09:21 AM
redefsir's Avatar
anyone?
Old Sep 4, 2007 | 09:33 AM
Targa250R's Avatar
be professional
The ignition switch and key tumbler are separate. It's a bit of a pain to remove though, because IIRC the bolts that secure the bracket to the column are of the break-away type that must be chiseled off.
There are actually two clutch switches on the pedal for some models IIRC (what car is it?); I'd start with those first.
Old Sep 4, 2007 | 10:08 AM
redefsir's Avatar
its a ef hatch.
the thing is, is that im geting power to the remote wire going to the starter solinoid when the key is turned.
that leads me to think that the switch on the clutch is good.
i also measured output from the starter relay and im getting 12v from that when the key is turned which leads me to think the ignition switch is good as well.
im thinking it maybe something internally with the starter solinoid.
Old Sep 4, 2007 | 10:18 AM
llslick's Avatar
I've had problems with ignition switches and tumblers on high mileage cars sounds like your problem
Old Sep 4, 2007 | 10:40 AM
redefsir's Avatar
Default Re: car wont start... no power to the starter. HELP????????? (llslick)
do you have any thing to add to that because thats a little vague?
i have power to the relay and to the starter when the key is turned so why would it definatley be the ignition switch?
Old Sep 4, 2007 | 12:12 PM
Targa250R's Avatar
be professional
It's not the ignition switch if it is sending power elsewhere when you turn the key.
Old Sep 5, 2007 | 03:33 AM
redefsir's Avatar
thank you....
im pretty sure its the solinoid itself!
Old Jan 27, 2010 | 08:32 PM
fastestsohcvtec's Avatar
sounds like ur solinoid is ur problem.
Old Jan 28, 2010 | 08:46 AM
EFM_ookie's Avatar
holy bring this thread back from the dead batman!!!!!
import-tooner
Aug 8, 2018 08:21 AM
Keino1
May 18, 2015 10:01 AM
91tegrals
Feb 12, 2012 09:03 PM
CamaroKilla
15
Feb 18, 2010 10:57 AM
SnlpeR
Oct 22, 2008 03:36 AM
