Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
finally building motor
Old Aug 31, 2007 | 02:51 AM
DJaeMac's Avatar
Default finally building motor
well, my car has been sitting in my garage for the past 3 months collecting dust with blown pistons. So now i've decided to finally fix the problem.....
im not K-swapping...
im just going to build the internals.
i had to tow my car to my friends shop and do the motor build there...
heres some pics so far...
and now the body sits while the engine is having its heart fixed
ill keep posted on the details...
so far i've managed to get:
Wiseco pistons (9.0:1 compression 76 mm)
Crower Rods
Clutch Masters Stage 3 clutch and flywheel
Cometic Headgasket
ARP Head Studs
I already had stage two port and polish started yesterday
i still need some 500+CC injectors unless the RSX-S injectors i got on will hold good enough.
Hope ya'll enjoy
Old Aug 31, 2007 | 05:03 AM
Curiouz_G's Avatar
looks good. what other mods do you have?
Old Aug 31, 2007 | 05:41 AM
toyomatt84's Avatar
Sanji
That front lip looks like a running board for a pickup.
Best of luck with the engine build, I hope all goes well.
Old Aug 31, 2007 | 05:54 AM
DsevenEm2's Avatar
cool mugen sticker... u should fix that too!.. looks good tho, keep us posted, hope it comes out beastly
Old Aug 31, 2007 | 07:15 AM
roost's Avatar
* B A N N E D *
get srt-4 577cc injectors i beleive all you need to do is rewire them and longer mounting bolts... like $100 on ebay or srt-4-*** site.
fventura03's Avatar
2 "moogen" 4 me
Old Aug 31, 2007 | 09:02 AM
DJaeMac's Avatar
Default Re: (Curiouz_G)
Additional engine mods:
T3 turbo
Intercooler w/ custom IC piping
Greddy Type-RS BOV
Greddy E-manage w/ support tool and harness
Greddy Map Sensor
Greddy Profec B-Spec II boost controller
RSX-S Fuel injectors
Walbro 255 lph fuel pump
ZEX Nitrous kit (through IC Piping)
AEM Adjustable CAM Gear
Old Aug 31, 2007 | 12:20 PM
DsevenEm2's Avatar
why e-manage?
Old Aug 31, 2007 | 01:58 PM
DJaeMac's Avatar
Default Re: (DsevenEm2)
dont have that much yet to upgrade that yet...
and plus, my emanage was workin just fine with my mods.
i think it could handle the new mods im doin
Old Aug 31, 2007 | 02:33 PM
Boilermaker1's Avatar
Trusting a built motor to e-manage.... yeesh.
If you've got the $2000+ to build the bottom end right, scrape up another 1100 for a Hondata box. Now that you're out of overbores.... try not to crack the sleeves if you crank the boost up.
Old Aug 31, 2007 | 04:33 PM
DJaeMac's Avatar
Default Re: (Boilermaker1)
how bout the e-manage ultimate?
where could i find the hondata one for our engine model?
Old Aug 31, 2007 | 04:36 PM
DJaeMac's Avatar
why wont e-manage be good enough?
Old Aug 31, 2007 | 05:13 PM
roost's Avatar
* B A N N E D *
e-manage is terrible with tuning..
It cant really tune partial throttle, it's been known to casue random lean spots.
I'll be waiting for your next thread "i blowed it up" while using emanage.
I would NEVER EVER run my engine on a piggyback whether it be stock/boosted or built/boosted
btw dont use rsx-s njectors use srt-4 they wont max out with 10psi.
Weren't you the one running like 13-16psi on stick engine too and said your engine was doing fine?
Old Aug 31, 2007 | 05:39 PM
DJaeMac's Avatar
yep...
but you were right bout the lean spots..
when i had the block taken apart, they told me i blew my piston due to a lean condition...
and the car was tuned, so im guessing it was the emanage...
would an emanage ultimate do?
Old Aug 31, 2007 | 07:36 PM
Curiouz_G's Avatar
upgrade to Kpro. From what ive heard personally, its the sh*t, hands down. even better than AEM EMS
Old Aug 31, 2007 | 08:44 PM
DJaeMac's Avatar
other than the kpro unit and the cam gear, what else will i need cuz i change some sensors when i used the e-manage
Old Sep 1, 2007 | 01:01 AM
1llmatic's Avatar
New User
AEM EMS, Hondata Kpro, HKS F-con V-Pro are all very good systems.
It all depends on what your tuner is most comfortable with.
If he's good at all the programs then just ask what he prefers to tune with.
Old Sep 1, 2007 | 01:06 AM
DJaeMac's Avatar
an update...
well, i went with the aem ems....
hopefully it does work out great...
i also got a set of 577cc srt-4 injectors
now for the fuel return system...anyone know how to do one?
Old Sep 1, 2007 | 08:13 AM
Curiouz_G's Avatar
theres a DIY on http://www.7thgencivic.com
Old Sep 1, 2007 | 10:36 AM
K20boiZ's Avatar
Default Re: finally building motor (DJaeMac)
what tires do you have on your car? and what size are they? nice car btw. hope the build up goes well.
Old Sep 1, 2007 | 01:14 PM
DJaeMac's Avatar
Default Re: finally building motor (K20boiZ)
thanks.
The tires on some generic ones they're 15's, but i wanna get some slicks....
what size slicks should i run for my car?
Old Sep 1, 2007 | 01:29 PM
DJaeMac's Avatar
cant find the DIY on the fuel return system
Old Sep 1, 2007 | 01:36 PM
DJaeMac's Avatar
nevermind....
found it thanks!!
Old Sep 1, 2007 | 05:56 PM
K20boiZ's Avatar
ok. it looks like you have slicks all the way around on the pic of it on the roll back. i was just checking.
slicks depend on your preference. but i'd say MT 24.5's. you can go down to a 22 if you want but i'd say 24.5 should work fine.
Old Sep 1, 2007 | 10:09 PM
DJaeMac's Avatar
THANKS!!...
would i mount those on a 15" rim?
