itr 5 lug conversion on ek PROBLEM. brakes doesnt work and doesnt have presure.
i just picked up a 5 lug conversion for my ek. everything bolted right up. bled the brakes and still wouldnt get any pressure. is there a special way in doing this. what am i doing wrong.
thanks
Modified by projektCRX at 12:15 PM 8/31/2007
thanks
found a leak at the master cylinder. WEAK. i still would like to know the correct process, whether it be left front, right front, left rear, right rear or what not.. thanks again.
Correct is RR, LF, LR, RF. If you don't have hydraulic pressure, you have a problem with your master. It's the part pushing the fluid through the lines. Do you just not have a solid pedal? Or is it spongy? Or what? Did you check the calipers to make sure the pistons are actually driving?
I think that you just need to bleed them properly, but without knowing full well what's happening, I can't make an accurate
simplegreenmachine
Jan 1, 2003 09:55 PM
