fuel line bleed Questions
Old Aug 30, 2007 | 10:35 PM
deerek101's Avatar
Default fuel line bleed Questions
k this is the deal my crx has been sitin for a while the dizzy went out so get a new one its a td03u for dual cam zc put it in no ploblem well i go to fire her up and i think the lil gas i had has been evaporated because its bone dry so i put some in now try to start again nothing now i cant hear the fuel pump when i turn the key on its got to be air in the line or bad fuel pump the motor starts with starting fluid so i know the spark is there any help on how to bleed the lines or test the fuel pump would be great thanks
Old Aug 31, 2007 | 08:53 AM
abnaasefmb's Avatar
Default Re: fuel line bleed Questions (deerek101)
crack the service screw, turn the ignition to the "on" position and lean over the fuel filter with a match so you can see if any fuel squirts out. if it does the "air" in your line is gone. if it doesn’t replace your fuel pump fuse or fuel pump.
hondastudent1on1
Jul 5, 2008 02:54 PM
4doorcivic9
Jun 11, 2008 06:31 AM
IP RACING
Nov 27, 2007 08:00 PM
DC_andrew
Jul 11, 2004 07:57 PM
esoterEK..
Feb 10, 2004 10:58 AM
