d16y7 in 91 Si!!
Old Aug 30, 2007 | 10:16 PM
EFstyle's Avatar
Default d16y7 in 91 Si!!
comin to the final stages of the swap and just had a few questions for those of you that have done this swap before. First what radiator hoses did you use? second there is a rubber peice on the wiring harness with 2 little round clips on the inside on the a6 wiring harness (same wing of the harness that the alternator plugs into) and i have no idea what to do with it. i know that there is some kind of senor that is on the back of the block on the a6 because i checked my 89 si. what did you guys do with these wires? also... extra noobish of me, but i have no idea wich spark plug wires go where on the dizy... thanks for the help in advance
Old Aug 31, 2007 | 09:06 AM
EFstyle's Avatar
Default Re: d16y7 in 91 Si!! (EFstyle)
Old Aug 31, 2007 | 01:41 PM
EFstyle's Avatar
c'mon... ive talked to plenty of people on here that have done this... help me out...
Old Aug 31, 2007 | 01:54 PM
jlicrx's Avatar
sounds like the connector is for the cooling fan switch which was on the back of the block on your old engine and is on the thermostat housing on the Y7 - you need to swap a 2-wire connector onto the wires and plug it in - spark plug wires are like this:
Old Aug 31, 2007 | 02:04 PM
EFstyle's Avatar
alright thanks... now if anybody knows what radiator hoses to use that would be fresh!
Old Aug 31, 2007 | 02:07 PM
jlicrx's Avatar
Default Re: (EFstyle)
CRX Si hoses should work
Old Aug 31, 2007 | 02:08 PM
EFstyle's Avatar
Default Re: (jlicrx)
are the rex and civic hoses the same?
Old Aug 31, 2007 | 02:12 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks... now if anybody knows what radiator hoses to use that would be fresh!</TD></TR></TABLE>
I am not sure exactly what engine the y7 is out of but most likely the hoses you need would come from that car (may be the same as 89 si but not sure) since most civic radiators have the same locations for the hose connections, the actual motor would dictate the needed hoses
edit: one way to tell which spot on the dizzy is the #1 cyl is to take of your cap and spin the motor over to tdc, just see where the rotor button is pointing and that will be your #1. of course you know all these 4 cyl motors have the same 1-3-4-2 firing order it;s just a matter of finding #1
Old Aug 31, 2007 | 02:44 PM
Jonknee's Avatar
Default Re: (VtecSyndrome)
you should be able to use your stock hoses man.
Old Aug 31, 2007 | 02:48 PM
AJxr's Avatar
Default Re: (Jonknee)
your gonna need to get swap the water neck piece that bolts to the head, i just put a d15b2 in my 97 hatch and i had to use the neck piece off of the y7 because they are angled different.
the bottom hose fits the same.
Old Aug 31, 2007 | 02:57 PM
Jonknee's Avatar
Default Re: (AJxr)
Actually now that i remeber ^^ that guy is right, when i used the y7 water neck the radiator hose was really twisted and i had to swap it.
Old Sep 1, 2007 | 08:15 AM
EFstyle's Avatar
wich uper radiator hose do i get then? should i just get the civic Si ones and change the fitting where the uper hose meets the head?
Old Sep 1, 2007 | 09:46 PM
nihad's Avatar
keep the fitting on the head the one with out the screw and use the stock radiator hose and custom fit it for it to fit nice all it needs is one bend in it just cut the stock on to where it fits.
bronxbomber0215
Mar 11, 2008 10:55 AM
Dwight Schrute
Nov 6, 2006 08:34 AM
JoSi
Nov 4, 2006 11:48 PM
Edgemingsr
Apr 29, 2005 10:13 PM
riceboyEFsi
Jun 7, 2003 12:16 PM
