Routing speedo cable
Old Aug 30, 2007 | 09:35 PM
.Grimace's Avatar
footwork mastery
Default Routing speedo cable
ok i have tried hooking this thing up a time or two and i cannot get it to the tranny. always an inch or two short. were do you put it through the firewall? if someone could make a quick ms paint picture i would greatly appreciate it.
Old Aug 30, 2007 | 10:13 PM
.Grimace's Avatar
footwork mastery
Default Re: Routing speedo cable (Gremice)
bump
Old Aug 30, 2007 | 10:20 PM
EFstyle's Avatar
Right behind your MAP sensor on the firewall about halfway down there should be a teardrop shaped hole... thats where its suposed to go...
Old Aug 30, 2007 | 10:25 PM
EFstyle's Avatar
Default Re: Routing speedo cable (EFstyle)
thats for an Si at least... idk what to compare it to if you have anything else
Old Aug 31, 2007 | 08:23 AM
SFlCrx's Avatar
connect the tranny side first. it is going to be very hard to route it the same way as stock so one you hit carpet make a small slit and run it up to the tach
Old Aug 31, 2007 | 08:33 AM
.Grimace's Avatar
footwork mastery
Default Re: (SFlCrx)
ahh alright. i'll take a look for that hole ty ef style. i'll let you know if it works...
Old Aug 31, 2007 | 09:08 AM
EFstyle's Avatar
Default Re: (Gremice)
I didnt have to connect the tranny end first... mine worked fine
RACEPAK
Aug 24, 2013 06:52 AM
95civicB16
Jul 21, 2007 12:55 PM
MANDO6669
Jun 7, 2006 09:19 PM
revlimitcrx
Apr 25, 2006 11:24 AM
spoonda6
Mar 3, 2003 11:47 PM
