benefits of the itr head on a b18c
Old Jun 14, 2002 | 02:41 PM
comptechgsr's Avatar
Default benefits of the itr head on a b18c
what are the benefits...besides cams..
Old Jun 14, 2002 | 02:43 PM
Padawan's Avatar
Darth ModerVader
Default Re: benefits of the itr head on a b18c (comptechgsr)
A healthy drop in compression. If you really want to do the swap, consider a thinner headgasket as well in order to offset the reduced compression. Otherwise, keep the C1 head and swap in the ITR components - less labor involved. Also keep in mind that the stock C1 intake manifold won't bolt up to the C5 head.
[Modified by Spec.R 00-0123, 6:49 PM 6/14/2002]
Old Jun 15, 2002 | 01:29 AM
vtecdc2's Avatar
Default Re: benefits of the itr head on a b18c (Spec.R 00-0123)
the c5 head drops compression? why is that? i would like to know.... isnt the c5 just a port and polished c1 head with a more agressive valvetrain?
Old Jun 15, 2002 | 07:15 AM
rodimus's Avatar
Default Re: benefits of the itr head on a b18c (HoL Lee SHieT)
the C5 or ITR head is a ported version of the CTR head.
Old Jun 15, 2002 | 07:22 AM
Project SSAP1's Avatar
keep the GSR C1 head and get a nice port and polish with portflow inernals and a set of CTR cams...u will b more than happy!!
Old Jun 15, 2002 | 07:28 AM
FAST94GSR's Avatar
New User
The combustion chambers are larger.. It is polished, not ported, mainly on the exhaust side. I wouldn't really call the valvetrain more aggressive, they do have dual valve springs to rev higher but that's about it.
Old Jun 15, 2002 | 01:25 PM
Padawan's Avatar
Darth ModerVader
Default Re: benefits of the itr head on a b18c (FAST94GSR)
Intake valves on the C5 flow slightly better than those on the C1 head as well. The C5 (or B16 for that matter) head is completely different than the C1, rather than simply a re-worked or modified piece.
Old Jun 16, 2002 | 02:53 AM
GZR4DR's Avatar
To answer the compression question, there is .2 points difference between the two. The ITR head/B16A head uses a circular combustion chamber while the GSR head utilizes a more squared off chamber. Some shops offer welding of the chambers to make it like a GSR head, i prefer running a thinner head gasket or using pistons to up the compression instead.
A GSR head with headwork and ITR internals mated with a Skunk2 or modified ITR intake manifold will yield better performance based off the slightly higher compression, as well as better flow characteristics.
Aim-MDMA
Sep 24, 2010 12:49 PM
Anthonyl469
Jun 24, 2004 06:37 AM
KB96VTEC
Dec 25, 2003 07:00 PM
navin
Apr 26, 2003 08:40 PM
SiBirdie
Oct 13, 2001 06:45 AM
