what axles do i buy for a b16a
Old Aug 30, 2007 | 04:32 PM
crxsteve's Avatar
Default what axles do i buy for a b16a
i have a b16a i need axles so i got 90 ls axles and the driverone don't go in thehalf shaft and the pass side seems loose
i don't know what axles to get
i have a b16 trans
thanks for the help
oh yea trans is a cable trans
Old Aug 30, 2007 | 05:10 PM
crxfreak1117's Avatar
Default Re: what axles do i buy for a b16a (crxsteve)
i dont see why ur having a problem i have the 90-93 ls axles in mine
Old Aug 31, 2007 | 08:09 PM
crxsteve's Avatar
Default Re: what axles do i buy for a b16a (crxfreak1117)
what half shaft are you runing?
Old Nov 23, 2007 | 04:42 AM
alscrx's Avatar
You prob have an sir halfshaft...You need raxles!
Old Nov 23, 2007 | 06:11 AM
ludesrv's Avatar
Default Re: what axles do i buy for a b16a (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">You prob have an sir halfshaft...You need raxles!</TD></TR></TABLE>
No. You don't. God. I hate noobs who don't know.
If you have a male halfshaft, 94+ teg axles non abs, remove the dust cap from the knuckles where the bearing is.
If you have a female halfshaft, 90-93 Teg axles non abs, remove the dust cap from the knuckles where the bearing is.
Get autozone axles. They come with lifetime warranty so you can snap them and replace them forever.
Old Nov 23, 2007 | 10:25 AM
alscrx's Avatar
Default Re: what axles do i buy for a b16a (ludesrv)
First, i am not a noobs cause i swap engines and tranny's all the time. And how can you say i don't know? He never stated which tranny he had so how can you rule out an SIR halfshaft if you know it all???? He said the axles didn't fit so he may have another halfshaft. You can't assume he has a 90-93 halfshaft know it all.
Make sure you didn't mix up pass and driver axle. Full splined inner cv always goes on left side into halfshaft.
hey crxsteve, check this out. It should clear everything up for you
http://www.hasport.com/news/ar...2.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
Get autozone axles. They come with lifetime warranty so you can snap them and replace them forever.</TD></TR></TABLE>
Old Nov 23, 2007 | 10:39 AM
alscrx's Avatar
Oh yeah, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
If he has a b16a like he stated with a cable trans why would he have a male halfshaft? JDM 92 up SiRs, 99-00 Si and Type R have this halfshaft which came with hydro tranny's!! Do you think i am still a noob who don't know,LOL
Old Nov 23, 2007 | 10:49 AM
turkishEF's Avatar
Easy buddy. Take comments like that, and toss'em out.
Some of us know that you know your ****.
I must not, never knew there were male intermediate shafts for the b-series.
Old Nov 23, 2007 | 12:15 PM
alscrx's Avatar
Default Re: what axles do i buy for a b16a (turkishEF)
Yeah your right... People ask for help and then others come and shoot it down like they are the only ones who ever worked on a car before.
94 and up Integra GSR have the male end on the left side
And JDM 92 up SiRs, 99-00 Si and Type R
Old Nov 23, 2007 | 02:35 PM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Yeah your right... People ask for help and then others come and shoot it down like they are the only ones who ever worked on a car before.
It's actually all B series hydro trans cars that ran the half shaft. The length of the driveshafts are the same on both sides you just have to buy for the kind of axles you have. I ran both styles before. It works awesome and the el cheapo 79.99$ driveshaft from autozone took my slick launch like a champ. Both on a B16 and B18. Best part they have a lifetime warranty, no questions asked. Why would you waist an extra 200$ or more on different axles.
I'm trying to let him know the exact information he needs, along with a wise
Old Nov 23, 2007 | 08:19 PM
alscrx's Avatar
I'm trying to let him know the exact information he needs, along with a wise </TD></TR></TABLE>
I agree, I ran autozone axles on my rex before the swap for more than 2 years with no problem.
Old Nov 23, 2007 | 09:08 PM
gunnerman's Avatar
you can get custom length axles from swapshopracing.com. 90-93 are a 1/4 in too long on oneside...
Old Nov 23, 2007 | 09:47 PM
alscrx's Avatar
Default Re: what axles do i buy for a b16a (gunnerman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnerman &raquo;</TD></TR><TR><TD CLASS="quote">you can get custom length axles from swapshopracing.com. 90-93 are a 1/4 in too long on oneside...</TD></TR></TABLE>
Who said they are too long??
Old Nov 23, 2007 | 11:27 PM
jeremycrxb16's Avatar
get the 89 teg axle, they are shorter and work better. i broke 2 1990 axles on my rex. a friend told me about the 89 and i have been using them for over a year now.
Old Nov 24, 2007 | 07:13 AM
alscrx's Avatar
Default Re: what axles do i buy for a b16a (jeremycrxb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremycrxb16 &raquo;</TD></TR><TR><TD CLASS="quote">get the 89 teg axle, they are shorter and work better. i broke 2 1990 axles on my rex. a friend told me about the 89 and i have been using them for over a year now. </TD></TR></TABLE>
You can't use 86-89 axles if you have a 90-93 teg halfshaft.
89 teg axles are shorter than 90-93 teg axles.
90-93 teg halfshaft is shorter than an SIR halfshaft
So putting a shorter axle with a shorter halfshaft makes the whole combo too short to work!
If your running an SIR halfshaft you do want to use the 86-89 teg axle BUT only the outer cv and shaft. You want to use the 90-93 inner cv joint because the 86-89 inner cv are shallow and will break easily. Yes the 86-89 axle will work but will not last. Hence the 86-89 teg didn't have a b16 in it!
Hope this helps
Old Nov 24, 2007 | 09:38 AM
CBURKE's Avatar
I just think he has an SIR half shaft and he needs to get a 90-93 half shaft. Or go pay mad money to have custom ones made.
Old Nov 24, 2007 | 12:54 PM
JakeSpec's Avatar
IF YOU HAVE AN sir HALFSHAFT YOU NEED TO BUY A 89 INTEGRA DRIVER AXLE!
Old Nov 24, 2007 | 12:55 PM
JakeSpec's Avatar
Default Re: what axles do i buy for a b16a (JakeSpec)
THAT HALFSHAFT NEED A 94+ INTEGRA AXL PART NUMBER FROM AUTO ZONE IS 8063
Old Nov 24, 2007 | 06:29 PM
gunnerman's Avatar
it's been tried and true...I have a friend who used the 89 inner joint combo and it's held up for 5 years and many track events..he's running about 180whp on a b16 in a crx..
using 90-93 ls axles will work but it is not the correct length
Old Nov 24, 2007 | 06:59 PM
gunnerman's Avatar
btw..i called swapshopracing and they said they'd give me the axles for $55 each with a core..
Old Nov 24, 2007 | 10:07 PM
ef-hatchcrap's Avatar
Did you try swapping axels from side to side?
The half shaft axel has splines all the way down to cv joint as to where the right side only has slines halfway.
Its just a suggetion who knows?
Old Nov 25, 2007 | 08:33 AM
CBURKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnerman &raquo;</TD></TR><TR><TD CLASS="quote">it's been tried and true...I have a friend who used the 89 inner joint combo and it's held up for 5 years and many track events..he's running about 180whp on a b16 in a crx..
using 90-93 ls axles will work but it is not the correct length</TD></TR></TABLE>
This is not true if you are useing the 90-93 half shaft, mine work fine.
Old Dec 3, 2007 | 08:43 AM
JakeSpec's Avatar
Default Re: what axles do i buy for a b16a (CBURKE)
its accordingly if your on a DA HS use da axles if your on a SIR HS use 1st gen integra axles or just driver side. if there still a lil long take off the plastic ring on the axle near axle seal ring a little extra room
Old Dec 3, 2007 | 11:10 AM
ED9man's Avatar
Driver's side 89 Integra, passenger side 90 integra
Old Dec 3, 2007 | 11:47 AM
mar778c's Avatar
Community Builder
Community Influencer
You need a 90-93 integra half shaft.
JustinG60
Jan 1, 2007 12:20 PM
shuttle xer
Dec 31, 2005 01:56 AM
boostin4drcivic
Jun 29, 2004 02:37 PM
b18crx
May 26, 2003 06:28 PM
Coricivic
May 21, 2003 08:29 PM
