DOHC ZC part numbers or USDM equivalents needed
hello
need some help with the last few bits I need for my swap; I need the Honda/Acura part numbers, or the USDM equivalent for a D16A8/9
DOHC ZC
1) front & rear main oil seals
2) pilot bearing
3) valve cover gasket
4) fuel filter
5) exhaust manifold-to-head studs
I am 90% sure that this stuff is the same as the 86-89 Integra (except for the valve cover gasket), but I want to make sure!
any help appreciated
greg v
DOHC ZC
2) pilot bearing
4) fuel filter
greg v
1) front & rear main oil seals - CRX SI
2) pilot bearing - not sure
3) valve cover gasket - i think its 88-89 integra
4) fuel filter - CRX SI
5) exhaust manifold-to-head studs - Any Honda I am guessing will work.. And you mean head to exhaust manifold right?
None of these are 100% positive, but I am atleast 75% sure..
you can use 88-89 integra rear/front main seals...
Rear Main Seal 91214-PH3-751 1989 Integra
Front Main Seal 91212-PE0-662 1989 Integra
not sure what you mean by pilot bearing. is there another name its called?
.kyle
Aug 9, 2012 07:21 PM
_Cyclone_
Jun 25, 2005 11:04 PM
