Rear disk brake conversion help!!!!!!
Old Aug 25, 2007 | 01:58 PM
2000jdmciv's Avatar
Default help with rear disk brake conversion
I just bought rear disk brakes for my 00 civic for $50 problem is all lines were cut and didn't come with ebrake cable or any other lines. What will i need to put these on my car and where is a good place to get the parts i need used/aftermarket?
Old Aug 25, 2007 | 02:19 PM
ej1sir16's Avatar
does your car have abs? the brakes came off a 00 si? the ebrake cables should work on your car , pretty sure all you need is the brake lines,um your best bet would find a junkyard with a 00 si, , find stainless steel braided lines, i think the company is called earls they make good stuff, try summitsportcompact.com
Old Aug 25, 2007 | 08:46 PM
BlueIntegraBoy's Avatar
Default Re: help with rear disk brake conversion (2000jdmciv)
Just get OEM replacements from your dealership. Get lines and ebrake cables from a 99-00 Civic Si.
47560-S04-932 WIRE A, L. PARKING BRAKE
47510-S04-932 WIRE A, R. PARKING BRAKE
01468-S04-900 HOSE SET, L. RR. BRAKE
01466-S04-900 HOSE SET, R. RR. BRAKE
Old Aug 30, 2007 | 03:10 PM
2000jdmciv's Avatar
Default Rear disk brake conversion help!!!!!!
(sorry for posting again but this time i have pictures) I have a civic and i want to do a rear dsik brake conversion so i found some cheap disk brakes and bought them for 50 bucks Problems is i dont know what they are off of and not sure what else i will need Heres pictures of the brakes
""also one of them seems to have a piece cut off of it is that a big problem or can i just take the whole arm from my old drum brakes?
The first picture is the one that is cut at the end
<center>
</center>
From what i know i will need brake lines, ebrake cable and not sure what else so if you guys could help me out it'd be great
thanks
Modified by 2000jdmciv at 4:27 PM 8/30/2007
Old Aug 30, 2007 | 03:11 PM
gezzuzz's Avatar
yes use your arms on your car now...
Old Aug 30, 2007 | 03:17 PM
2000jdmciv's Avatar
Default Re: help with rear disk brake conversion (BlueIntegraBoy)
i have a 2000 civic and i have these rear disk brakes but i dont know what they're off of i posted a new fourm with detailed pictures of the brakes
EL Vap133's Avatar
Default Re: Rear disk brake conversion help!!!!!! (2000jdmciv)
The LCA looks like a 96-00 Civic LCA. They must have come off a 99-00 Si or if any of the 96-00 EX's came with rear disc brakes possibly from an EX.
Look in here, there is a thread that tells you how to use your old arms for the swap: https://honda-tech.com/zerothread/1998336
Old Aug 30, 2007 | 03:18 PM
2000jdmciv's Avatar
my car doesn't have abs
Old Aug 30, 2007 | 03:19 PM
EL Vap133's Avatar
Use 99-00 Si e-brake cables and brake lines.
Old Aug 30, 2007 | 03:22 PM
2000jdmciv's Avatar
Default Re: Rear disk brake conversion help!!!!!! (EL Vap133)
alright sounds good thanks for the info
Old Aug 30, 2007 | 03:28 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000jdmciv &raquo;</TD></TR><TR><TD CLASS="quote">alright sounds good thanks for the info another questions how possible is it to put abs in a civic w/o it?</TD></TR></TABLE>
Why add ABS? It will only cost you much more $$$.
Old Aug 30, 2007 | 03:30 PM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Why add ABS? It will only cost you much more $$$. </TD></TR></TABLE>
I concur, ABS ftl.
Just leave it off/unplugged/disconnected/etc
Old Aug 30, 2007 | 03:43 PM
2000jdmciv's Avatar
Default Re: Rear disk brake conversion help!!!!!! (ek forever guy)
Yeah i wasn't sure if it was hard or not to add it i honestly could care less if i had it or not. So from what i'm getting i should just get 99-00 si ebrake/brakelines and then i will use my old arm to replace the messed up one
Old Aug 30, 2007 | 03:48 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000jdmciv &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i wasn't sure if it was hard or not to add it i honestly could care less if i had it or not. So from what i'm getting i should just get 99-00 si ebrake/brakelines and then i will use my old arm to replace the messed up one</TD></TR></TABLE>
Correct!
Old Aug 30, 2007 | 06:06 PM
MeanGreenMachine's Avatar
well what all needs to be done if your 96 and up civic coupe has abs and you want to retain it and ur using the rear disc brake setup off of a 99-00 si????
also, wouldnt 96 and up integra rear disc brakes work on 96 and up civics???
what about the proportioning valve? isnt that needed to complete the rear disc conversion?
Old Aug 30, 2007 | 06:47 PM
polything's Avatar
dont ABS. you can get the parts from a wrecked SI....just be patience,
or you can go with aftermarket brake lines
mhi
Suspension & Brakes
Jun 30, 2012 11:16 PM
bboyjimpy
Apr 25, 2010 07:30 AM
813EK
Jan 22, 2008 08:02 AM
enrique
Feb 26, 2004 05:17 PM
Jason kiDD
16
Apr 30, 2003 07:05 AM
