WTB----1.8L BLOCK LS OR GSR----MUST BE COMPLETE!!!!
i got a b18a1 block bored to 81.25mm with scat h-beams srp 11.1 pistons. all balanced and blueprinted. motor has around 10k on it now. still in my car. i want to build something new, thats why i want to sell it. $1000 takes just the assembled block with out the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16civster »</TD></TR><TR><TD CLASS="quote">LIKE IT SAYS.... SHOW ME WHAT U GOT</TD></TR></TABLE>
Would you be interested in a B16??
jdm b16 block
bored .50 mm over
fresh hone
hot tanked
checked for cracks and/or leaks
decked
fully balanced buttom end (whole rotating assembly)
ctr pistons .50mm over
stock b16 rods
micro polished crank
itr oil pump
itr water pump
new rod bearing
new main bearing
new thrust washers
je pro seal rings
Guy I bought it from says he had about 3k miles on it before he went turbo LS
jdm b16 block
bored .50 mm over
fresh hone
hot tanked
decked
stock b16 rods
itr oil pump
itr water pump
new rod bearing
new main bearing
new thrust washers
je pro seal rings
b18c1
stock bore 9-1 je pistons
eagle h beams
new bearing and rings clevite bearing aris rings
head is stock just cleaned up
harness is obd 1 or 2 custom harness
rc 550 injectors
complete with turbo kit if ur interested pm me and ill give u more details
eagle h beams
rc 550 injectors
