Coolant leak prelude '88
hi all,
My prelude is started leaking untifreeze, but i cant see where its coming from. when the car is running its not leaking, once you shut of the engine you can see a big puddle of coolant on the ground, but there is no way to tel where it is coming from, any ideas? before i could smell it a little bit while driving but it never leaked like that.
thank you all for your help.
which lude do you have? 88 S or Si. i don't think it matters, you could be leaking coolant from th eback of the engine. I know the 88 S have colant line that run to the carb. some times they burst and trickle down the back of the engine. another thought, how is your heater core hoses holding up? that's one other place that i would look. or even another place would be under the radiator. drain valve might have backed out, highly unlikely but just a thought. take a flash like and look all around your hoses and check for cracks.
Evolution-93-Ex
11
Jul 2, 2006 11:31 PM
