90 Accord coolant leak
Old Aug 30, 2007 | 12:00 PM
Jimd's Avatar
Default 90 Accord coolant leak
My 90 Accord has an intermittent coolant leak that appears to be coming from the the right side of the timing cover running down the block. Kinda of odd because it leaks only sometimes. Any ideas on this one?
Thanks ~ Jim
Old Aug 30, 2007 | 12:12 PM
Bruce Banner's Avatar
Default Re: 90 Accord coolant leak (Jimd)
Are you over filling?
Old Aug 30, 2007 | 12:33 PM
Jimd's Avatar
Default Re: 90 Accord coolant leak (Bruce Banner)
Negative. I add about a quart a week. How would you over-fill a closed system?
Old Aug 30, 2007 | 12:57 PM
that little extra resevoir container next to the radiator.
You top off there and if over filled it can leak out there.
Old Aug 30, 2007 | 01:07 PM
accord99power's Avatar
so towards the back of the engine or front? Or are you refering to right side of the engine near the timing cover? Heres the best trick, engine degress your engine then pressure wash, cover distributor first. check the hoses that go to the throttle body. may be the water pump though. if u know how to take off the timing cover look to see any evidence of radiator fluid. just my advise!
Old Aug 30, 2007 | 02:20 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
you guys are dumb...obviously it sounds like a head gasket problem...sheesh
Old Aug 30, 2007 | 04:05 PM
Default Re: 90 Accord coolant leak (I got the CD5 Jeebies!)
hmmm man last time i check water pump leak too but gasket would be my guess if he said it was lower on the engine.
Old Aug 30, 2007 | 04:19 PM
someone else's Avatar
It Wasn't Me!
Default Re: 90 Accord coolant leak (accord99power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">hmmm man last time i check water pump leak too but gasket would be my guess if he said it was lower on the engine. </TD></TR></TABLE>
Head gasket leak will usually be higher up. Water pump leak will usually show from about halfway down the back side of the block or lower. Look for a trail of crystalized coolant. If it's dripping out the bottom of the timing cover it is more likely a water pump.
If you can get under the car you can quite often gently pry the lower cover back about midway up and see if it is the water pump. Not always though. You may have to pull the covers to find out for sure.
Old Aug 30, 2007 | 05:16 PM
dion91Ls's Avatar
sounds like the waterpump to me
Old Aug 31, 2007 | 06:06 AM
Jimd's Avatar
Thanks for all the replies.
I just opened timing cover and it looks like the water pump. Now I'm guessing the fix means doing a timing belt and whatever else comes off to replace the pump.
Old Aug 31, 2007 | 06:39 AM
It Wasn't Me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimd &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the replies.
I just opened timing cover and it looks like the water pump. Now I'm guessing the fix means doing a timing belt and whatever else comes off to replace the pump.</TD></TR></TABLE>
Good idea to do the cam, crank and balancer shaft seals while you are in there as well. Nothing worse than putting a new belt on and having it get oil soaked. I would also not reccomend using a cheap water pump. Anytime I see a waterpump leaking before it's interval it been an aftermarket pump.
Old Aug 31, 2007 | 06:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">you guys are dumb...obviously it sounds like a head gasket problem...sheesh </TD></TR></TABLE>
someones advise just got burned!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someone else &raquo;</TD></TR><TR><TD CLASS="quote">
i wasnt sure he he knew the difference between the block and head, thats why i refered to the lower engine.
Old Sep 1, 2007 | 02:39 PM
And?? I had the motor pictured wrong in my head...for some reason I was tinking dizzy side mistakes do happen Im over it
agartthean
Nov 14, 2014 08:14 AM
tt3
Apr 9, 2011 07:23 PM
matter99
Sep 30, 2008 01:09 PM
Random.Hero
Sep 13, 2007 07:56 PM
