Built 99 gs-r
Old Aug 30, 2007 | 10:50 AM
toolfan020's Avatar
Default Built 99 gs-r question
Built bottom end bored out to 81.5 mm, honed
je 11:5.1 pistons
je proseal rings
eagle h beam rods
custom cometic head gasket
polished gsr crank
new oem acura main bearings/rod bearings
b&m fpr
everything else is stock gsr
head is stock currently... thats what I want to change. I guess im looking for advice on the best thing to do to add decent power for this n/a build. My goal is 200 - 225 whp for now.
I was planning on doing a type r (p73) ecu and a je intake manifold, would you all suggest a type r manifold instead as a alternative?? Also head wise would type r cams be better or should I go with skunk2 or brian crower? I'm assuming bigger injectors, cam gears, retainers, springs, and valves. Anything else I should consider? I'm welcome to all opinions/suggestions or input from anyone who has had a similiar build. Thanks!
Old Aug 30, 2007 | 11:04 AM
cartune network's Avatar
Default Re: Built 99 gs-r question (toolfan020)
sounds like a pretty good build but for one thing the type r intake manifold does not bolt up to the gsr head. i would go with an aftermarket cam, springs and retainers and maybe get a port on the head. ull make power without all that stuff but ull make alot more with it. with cams and a port ull be over 200whp with a tune
Old Aug 30, 2007 | 12:16 PM
toolfan020's Avatar
Default Re: Built 99 gs-r question (cartune network)
Yea I was thinking about a port and polish like the type r heads have. Thanks for the input cartune, what aftermarket cams and valve train would you recommend? I'm thinking either skunk 2 or brian crower? It currently has a p28 chipped ecu so I can either get that tuned afterwards or go with s300 hondata. So many options lol. Anyone else have similiar experience or have any advice?
Old Aug 30, 2007 | 12:34 PM
well the hondata s300 is a better program and base for tuning. brian crower is having a sale on cams if u call them and order from them i think its 10% off or 400 for a set. skunk 2 cams arent too bad but with that comp ratio u cant go too big. im using a set of buddy club spec 3's on my itr with a stock bottom end i made 216whp. pretty good considering. just do a lil searching on here to see what people are running. the skunk 2 pro 1's might be pretty good for your setup. i would definitly get a good port if u can afford to.
Old Aug 30, 2007 | 05:42 PM
toolfan020's Avatar
Anyone else have any experience with a all motor gsr or have any input?? Thanks
Old Aug 31, 2007 | 11:39 AM
projectcivicjp's Avatar
skunk 2 mani does pretty good or maybe a blox. blox hsl cams with some supertech high comp valves and valvesprings and retainers. good luck with the build.
Old Aug 31, 2007 | 09:01 PM
toolfan020's Avatar
Thanks, were spending the weekend assembling the motor and dropping it in, im going to build the head in the next month or two. How much do the supertech valvetrain components usually run?
Old Aug 31, 2007 | 09:20 PM
all-mtr-teg's Avatar
Default Re: (toolfan020)
valves $200, v.s. $150, just stick w/ oem ret. and keepers.
Old Sep 1, 2007 | 07:08 PM
toolfan020's Avatar
Default Re: (all-mtr-teg)
You all think the supertech vs skunk2 or bc are just as good?
Old Sep 1, 2007 | 08:11 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolfan020 &raquo;</TD></TR><TR><TD CLASS="quote">Yea I was thinking about a port and polish like the type r heads have. Thanks for the input cartune, what aftermarket cams and valve train would you recommend? I'm thinking either skunk 2 or brian crower? It currently has a p28 chipped ecu so I can either get that tuned afterwards or go with s300 hondata. So many options lol. Anyone else have similiar experience or have any advice? </TD></TR></TABLE>
Type r head isn't "ported and polished" by any means. It has very mild work behind the valve head itself... and when I say mild, I mean mild. By no means does it even begin to compare with the work a professional head porter would do.
streetdemons
Feb 16, 2009 10:09 AM
toolfan020
Aug 30, 2007 04:29 PM
.Ash
Jan 27, 2004 08:25 PM
boo00st
Sep 30, 2003 09:07 PM
GSRoadRage
May 28, 2002 05:22 PM
