Cheap alternative to the small battery alot of us use.
Old Aug 30, 2007 | 10:33 AM
AudioXtremes's Avatar
Default Cheap alternative to the small battery alot of us use.
I currently run this battery and it starts the car just fine. While I don't recommend it for anyone with lots of accecories. This is for those people who are thinking of purchasing a Kinetic 600, Batcap 800, Or Odyssey 680.
FYI this is the SAME battery as the Batcap and Kinetic. Only has different terminals from the factory.
http://www.portablepower.com/i...105S3
Modified by AudioXtremes at 7:54 PM 8/30/2007
Old Aug 30, 2007 | 10:34 AM
Default Re: Cheap alternative to the small battery alot of us use. (AudioXtremes)
Compare to the batcap 800 http://www.batcap.net/800.html
And the kinetic 600 http://www.kinetikaudio.com/hc600.asp
Old Aug 30, 2007 | 10:35 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Kick ***!
Always nice to see some info like this out and being added to us 4th genners
I would get this but I just got an oddesy and love it
Old Aug 30, 2007 | 11:37 AM
garageEF's Avatar
Default Re: Cheap alternative to the small battery alot of us use. (The Maxidermist)
nice find ive been thinking about experimenting with lawn mower and jet ski batterys.
Old Aug 30, 2007 | 11:42 AM
ExospeedAMcrx's Avatar
Default Re: Cheap alternative to the small battery alot of us use. (garageEF)
ya ive used that type fo battery back in 1998 or so. They last pretty long. Had one in my CRX with a custom mounting bracket on the right side frame above the crossmember. Lasted for a couple years. didnt have stereo system or anything but good for a lightweight alternative.
Old Aug 31, 2007 | 03:39 AM
Default Re: Cheap alternative to the small battery alot of us use. (ExospeedAMcrx)
Yes they last a good long while. Very small.
Old Aug 31, 2007 | 07:13 AM
pauld's Avatar
Just did a conversion to a lawn-tractor battery in my crx. Had to change battery terminals, but other than that works great!! I needed some clearance between my air intake (like everyone) and wanted a lighter battery, but I'm a cheapass, so the $30.00 (canadian) lawn tractor battery went in, right into the factory tray (with some mods to the hold-down bracket for the shorter battery height) Starts the car with ease, accidentally left my lights on last night while paying for gas & eats , no problem starting!!! A great cheap alternative, you just need to buy the terminal ends for "wingnut" attachment
Old Aug 31, 2007 | 08:07 AM
peanut butter's Avatar
Default Re: Cheap alternative to the small battery alot of us use. (pauld)
Your link in the OP doesn't work right now, what is the name of the battery you are refering to?
Old Aug 31, 2007 | 10:27 AM
nuckingfuts's Avatar
Default Re: Cheap alternative to the small battery alot of us use. (peanut butter)
30$, 14lbs!
Taken from their product description PDF:
"Limit initial current to 5.4Amps. Charge battery until voltage (under charge) reaches 14.40 to 14.70 volts at 68F. Hold at 14.40 to 14.70 volts, until current drops to approximately 180mA. Battery is now fully charged under these conditions, and the charger should be turned off or switched to "float" voltage."
this is a picky battery? lol
Old Sep 1, 2007 | 04:27 AM
rice a roni's Avatar
so are you guys getting smaller batteries just so you can relocate the battery to a different spot??
Old Sep 1, 2007 | 05:59 AM
fireant's Avatar
Default Re: Cheap alternative to the small battery alot of us use. (rice a roni)
Maximum Short-Duration Discharge Current ( <_ 10 Sec.) 180 amperes
Would that mean 180 CCAs?
Operating Temperature Range:
Charge (-20oC) to 122oF (50oC)
Discharge (-20oC) to 140oF (60oC)
It might get too hot in the engine bay for these in lower states, but fine inside the hatch.
Old Sep 1, 2007 | 06:03 AM
fireant's Avatar
Default Re: Cheap alternative to the small battery alot of us use. (fireant)
Flame-retardant version, $45, 13.3lbs
http://www.portablepower.com/i...105S1
The_Head
Honda Motorcycles
16
Feb 27, 2011 02:19 PM
ICeDoUt
Jul 28, 2003 06:35 PM
SmokyMtnRex
15
Dec 31, 2001 11:16 PM
