HEAD GASKET QUESTION
Old Aug 30, 2007 | 10:29 AM
DSRacing's Avatar
Default HEAD GASKET QUESTION
i have a ls/v 81x89 gsr head(milled .010) with a 3 angle valve job and skunk(oem size) valves, my pistons are wiesco(12.4:1) on eagle rods with a dome dish of 8.25 NOW the question i had my buddy place the order as i was at work and he ordered a .045 head gasket correct me if im wrong but since head is milled .010 that would make the gasket more pf a .035 is this safe to run?
Old Aug 30, 2007 | 11:07 AM
cartune network's Avatar
Default Re: HEAD GASKET QUESTION (DSRacing)
as long as u plan on running high octane. i personally would get a .055 head gasket but idunno. u might wanna check your piston to valve clearances. but you should be ok.
Old Aug 30, 2007 | 11:45 AM
DSRacing's Avatar
yea dont drive this car just tow it to the track so it will only have 103 gas and i called cometic it was not ship out yet so im going to see if i can change the order next size up i think is a .052
Old Aug 30, 2007 | 12:35 PM
Default Re: (DSRacing)
what cams r u running?
Old Aug 30, 2007 | 12:38 PM
DSRacing's Avatar
they are called "blueprint" stage3 they are like a blox cam but not so perfect i think it has a lift of 12.6 NOW skunk stage2 has a 12.4 lift and stage3 has 12.8 so my cam is like a stage 2 1/2
Old Aug 30, 2007 | 12:42 PM
just make sure ull have the clearance with the gasket.
Old Aug 30, 2007 | 12:44 PM
DSRacing's Avatar
Default Re: HEAD GASKET QUESTION (cartune network)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">as long as u plan on running high octane. i personally would get a .055 head gasket but idunno. u might wanna check your piston to valve clearances. but you should be ok.</TD></TR></TABLE>
there is no 55 its .051 or .060 but my compression should be 12.4:1 ok with the 51 its like 12.1 almost 12.2 with the 60 it drops to like 11.8 or 11.9
Old Aug 30, 2007 | 01:01 PM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRacing &raquo;</TD></TR><TR><TD CLASS="quote">i have a ls/v 81x89 gsr head(milled .010) with a 3 angle valve job and skunk(oem size) valves, my pistons are wiesco(12.4:1) on eagle rods with a dome dish of 8.25 NOW the question i had my buddy place the order as i was at work and he ordered a .045 head gasket correct me if im wrong but since head is milled .010 that would make the gasket more pf a .035 is this safe to run? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRacing &raquo;</TD></TR><TR><TD CLASS="quote">yea dont drive this car just tow it to the track so it will only have 103 gas and i called cometic it was not ship out yet so im going to see if i can change the order next size up i think is a .052</TD></TR></TABLE>
You're using 103 octane so you should be alright with the compression..
As for clearances, you should clay your motor to see if its safe..
Old Aug 30, 2007 | 02:25 PM
DSRacing's Avatar
i broke this motor in on a .060 and everything kept going wrong motor kept cutting out but it could have been a million reason need ignition or dizzy went bad needed a high gas i was on pump or just needed to be tuned or cause seals and guides went out haha or cause a ebay header and stock eg pipe dont go good with my motor. fix the head got a new dizzy looking for 370 should have them tomorrow and ill tune with in the month and ill have a profab or something like that. its to late to clay the motor. i just hope this .042 is safe(0.052-.010=.042)
Old Aug 30, 2007 | 08:49 PM
Chris Tune's Avatar
better late to clay than sorry with a broken engine with 8 exhaust valves sunk deep in your pistons
Old Sep 4, 2007 | 01:34 AM
DSRacing's Avatar
it was changed for a .051 a little better but haha i feel dumb cuz now im thinking i want the 60 to feel a little safer
Old Sep 4, 2007 | 09:48 AM
ChickenH's Avatar
clayings easy. it will only take you an hour. and some silly putty.
boostjunkieee
Mar 30, 2007 03:07 PM
Drag-Accord
Mar 23, 2005 10:20 PM
stinger
Jul 24, 2004 08:32 PM
