Another attempt of a d16a6 to y8 conversion
Old Aug 30, 2007 | 08:30 AM
scorpion_86403's Avatar
Default Another attempt of a d16a6 to y8 conversion
I have a 88 Honda Crx D16A6 and i want to use a Y8 head. I've read tons of these forums and still havent figured out what i need?! If I have the whole y8 head/intake setup what else do i need?? Besides new assembly parts, do i need Vtec controller? Ecu upgrade?
Old Aug 30, 2007 | 08:55 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Another attempt of a d16a6 to y8 conversion (scorpion_86403)
There is more then enough info on mini mes, I don't know how you missed it but here is one write up.
https://honda-tech.com/zerothread?id=554053
only thing for you is you'll have to wire up to obd1, and you can do that with a nifty boomslang.us harness
Old Aug 30, 2007 | 09:16 AM
Default Re: Another attempt of a d16a6 to y8 conversion (The Maxidermist)
Will a Apex Vtec controller do the trick?
Old Aug 30, 2007 | 09:18 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scorpion_86403 &raquo;</TD></TR><TR><TD CLASS="quote">Will a Apex Vtec controller do the trick?</TD></TR></TABLE> For what exactly?
To control vtec, yes it can, but it's not the best way.
To tune, please don't for both of us.
Personally you are much better going obd1 and getting a good burnt chip
heck even a stocker p28 i'd want over a vafc.
Old Aug 30, 2007 | 11:00 AM
D16SiHatch's Avatar
Or you could use a rpm activated switch for vtec and screw obd1 and the harness altogether.
Also two more great pages to use that are located in the fact at the top of this section.
http://crx.honda-perf.org/arti....html
Im doing this swap actually pretty soon, im waiting for some parts to come into the honda dealership before i can start.
Heres everything you'll need if you want to do it without switching to obd1..
-y8 head (obviously)
-y8 headgasket
-timing belt from d15b7 (1992-1995 civic DX/LX)
-adjustable cam gear (need to advance timing 4.5 degrees)
-One y8 headbolt for the bolt nearest the vtec solenoid (need y8 bolt because its shorter and if you use the a6 bolt it will bottom out and not allow it to be torqued down properly)
-Intake gasket
-Exhaust gasket
-vtec rpm activated switch from summit racing (for vtec engagement)
Old Aug 30, 2007 | 11:01 AM
89efDUSTY's Avatar
Please save your motor and the hassle, please go OBD1 running a p28 and just purchase the complete Rywire conversion.
Not to be a douche or anything, but I have the Rywire Jumper and Sub vtec harness for this set up. Also I have the d16y8 dizzy that plugs into the a6 clip. Seriously you cannot get easier plug and play than that PM me for more information
JAYSCRX420
Jul 14, 2018 11:39 AM
nis240rb
Jan 29, 2008 04:47 PM
88civhatch
11
Sep 13, 2005 05:12 PM
Skinflute22
Aug 9, 2005 12:29 PM
sCeRaXn
Aug 16, 2002 12:55 AM
