IAC valve
Old Aug 30, 2007 | 06:17 AM
jlfrnce's Avatar
Default IAC valve
i have a 94 ls with gsr swap and now after 5 months of driving i now throw a code for the IAC valve and the code is 14. i have switched with 3 other iac valves and still get the same code and problem! thanks for the help in advance!
Old Aug 30, 2007 | 09:49 AM
GSR-TRBO-DA's Avatar
Default Re: IAC valve (jlfrnce)
check and see if you have a cut or damaged wire or if you have continuity.
Old Aug 31, 2007 | 03:30 AM
jlfrnce's Avatar
Default Re: IAC valve (GSR-TRBO-DA)
yep 1 of the wires were broke, went threw a total of 4 and the looked at wiring, thanks for the help!
Eliot Tapia
May 27, 2019 06:18 PM
strum456
Jan 15, 2013 03:43 AM
truword1
Honda Civic (2001 - 2005)
Mar 5, 2009 04:44 PM
"93XSi"
Dec 24, 2005 09:22 PM
Dc_Ek
Dec 8, 2005 03:37 PM
