radiator / headers help!!!
Old Aug 30, 2007 | 05:01 AM
bronxbomber0215's Avatar
Default radiator / headers help!!!
i have just orderd an after market radiator with headers .........i installed the headers but the the down pipe sounds like its ratling(only when on 1500 rpms)..... not sure of what to do with that..................the radiator i got doesn't allow the hoses to go on compltely........and will not allow the hood to close if any 1 can help plz do ...thanx
Old Aug 30, 2007 | 07:50 AM
EF_LSVtec's Avatar
Default Re: radiator / headers help!!! (bronxbomber0215)
about the header...you may have to put your car on a lift and see where it's rubbing, causing the rattle. As for the radiator, can you take a pic or maybe use a longer/larger hose? Is there more space on the bottom that you can possible move the 2 mounting studs so you can close hood? Or can you return it??
JDM_95_LS
Apr 13, 2007 05:42 PM
gmb
Sep 25, 2005 10:36 PM
btole
Mar 24, 2004 03:16 PM
