4x114 conversion
Old Aug 29, 2007 | 11:59 PM
EFin' Kyle's Avatar
Default 4x114 conversion
has anyone done this? do i need to change my LCA's or brake lines? passwordjdm sells the ITR 4x114 conversion but with no LCA's or brake lines or anything. anywho if anyone has any info on how to do the conversion or if they have done it. all info would be greatly appreciated
-Kyle
Modified by Good Ol' Kyle at 1:13 AM 8/30/2007
Old Aug 30, 2007 | 12:31 AM
ozrednsx's Avatar
Default Re: 4x114 conversion (Good Ol' Kyle)
you dont need the LCA's from the swap. and you can use your oem rubber brake lines.
The rear swap is just like any other rear disc swap...retain all your arms (lca, uca, and toe end link) and just swap the trailing arm. You can use the ebrake lines off the conversion but they are longer and may be a little harder to work with.
As for the front when i got the conversion from extremejdm he told me that i can bolt on everything as is. But when i brought everything home i had compared the knuckles side to side and they are different. The route i had taken was swapping out the hubs onto my oem ones so i wouldnt encounter any problems.
Just letting you know though...if you are planning on keeping the calipers off the 96 4x114 you may have a problem finding the right pads and rotors since they are jdm.
Old Aug 30, 2007 | 12:49 AM
EFin' Kyle's Avatar
Default Re: 4x114 conversion (ozrednsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozrednsx &raquo;</TD></TR><TR><TD CLASS="quote">you dont need the LCA's from the swap. and you can use your oem rubber brake lines.
</TD></TR></TABLE> wow awesome thank you. i had heard that the calipers and rotors were very similar to the gsr calipers and rotors.
Old Aug 30, 2007 | 01:01 AM
EFM_ookie's Avatar
Got to love 4lug type r wheels on a EF
Old Aug 30, 2007 | 01:50 AM
EFin' Kyle's Avatar
Default Re: 4x114 conversion (EFM_ookie)
wholy f*ck i saw some lights outside my window and this freaking EK was outside with its lights off trying to break into my neighbors civic. they took off when i opened my blinds and then i went outside to see if they did anything and they didnt thank god. then i get in my car to go get some food and this white van is parked around the corner with his lights on and he pulls up behind me and starts following me. WTF anywho so i speed off and loose him. but dang that was weird. ugh! well bump for some great info on the lug conversion =_P
-kyle
Old Aug 30, 2007 | 02:05 AM
EFin' Kyle's Avatar
thing that sux is when she first moved in next door. after 3 weeks someone took a crowbar to her door and messed it all up =/ i dont think i'll be posting any pix of my car on here =P i would go crazy if someone stole my car.
Old Aug 30, 2007 | 02:09 AM
EFM_ookie's Avatar
as soon as i get my JDM front im gettin lojack for more info on this conversion or pics
Old Aug 30, 2007 | 02:11 AM
EFin' Kyle's Avatar
yeah pix would be kool. when i do it i think i will post pix of the process.... not my car tho =P make a thread about it so people will know
Old Aug 30, 2007 | 03:39 AM
No1$HeR0's Avatar
Hey are the brake rotors 10" or 9" on those 4x114 '96 ITR rear disk brakes?
EFin' Kyle's Avatar
Default Re: 4x114 conversion (No1$HeR0)
they are the exact same as the GSR. dont know if that helps
Old Aug 30, 2007 | 09:07 PM
ozrednsx's Avatar
Yea for the rear discs...everything should be the same off a regular usdm integra...
Best thing for rotors for the rear is to purchase 4x100 rotors and just have them redrilled to the 4x114 pattern.
I have had DA trailing arms along with the 96 ITR at the same time and i was able to swap out the calipers at the time. And the rotors were the same dimensions except for the bolt pattern. Im not too sure about the pads...so if you cant ever find the proper pads you can simply buy usdm caliperrs and just swap them out.
The front...I dont know the exact model (but i believe the 96+ prelude vtec rotors NOT FOR SURE) but to skip all the confusion i just called up brian at fastbrakes and ordered 96 itr rotors. I dont know if you are anywhere near westminister but fastbrakes distributes rotors from a rotor shop there and rather than dealing through the phone i bring the exact rotor i need and have them spec it and they would have the right rotor the next day.
Also if you plan on using the 96 ITR wheels the offset on the wheels are +40 and with the whole conversion the wheels dont sit flush with the body...
this picture (not my car) shows what im talking about with the front wheels not being flush with the body
and here are some pictures of the conversion done
Old Aug 30, 2007 | 09:46 PM
Swipe'd's Avatar
bump 4 my man oz, he knos his ****!
Old Aug 30, 2007 | 10:21 PM
ozrednsx's Avatar
Default Re: (Swipe'd)
thanks swipe'd
hows the rex going...
To the OP i suggest you trying somewhere else other than pwjdm...possibly hmotors or extremejdm because pwjdm usually sells stuff broken, missing parts, and really expensive just because they believe theyre the only ones who has it. As for hmotors and extremejdm they dont sell stuff broken and if you ever deal with vince at extremejdm he is always willing to help, work out the price if something is missing, or even replace parts if they are broken once noticed
Old Aug 30, 2007 | 11:56 PM
iheartjayDem's Avatar
do you live in socal? i can get the complete 96 itr 4X114 conversion with wheels for 650
Old Aug 31, 2007 | 05:59 AM
EFin' Kyle's Avatar
Default Re: 4x114 conversion (iheartjayDem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozrednsx &raquo;</TD></TR><TR><TD CLASS="quote">Yea for the rear discs...everything should be the same off a regular usdm integra...
yeah i planned on using the 96' ITR wheels. cant u use a wheel space and extended studs? anyway just a thought and than you for the info with the DA trailing arms. yeah i live about 50 minutes form westminster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartjayDem &raquo;</TD></TR><TR><TD CLASS="quote">do you live in socal? i can get the complete 96 itr 4X114 conversion with wheels for 650</TD></TR></TABLE> KOOL! PM
Old Aug 31, 2007 | 10:28 PM
ozrednsx's Avatar
yea..i used spacers and extended studs
Old Sep 6, 2007 | 12:04 AM
EFin' Kyle's Avatar
Default Re: 4x114 conversion (EFin' Kyle)
Old Sep 6, 2007 | 01:52 AM
STREETWERKZ's Avatar
kyle, you may want to rethink the 4x114 swap.
say you get a flat.... where you gonna find a spare in a hurry?
4x100 FTW! everyone has a spare set of steelies in their backyard that they can loan ya.
Old Sep 6, 2007 | 02:28 AM
JKGONZALEZ3's Avatar
Default Re: 4x114 conversion (STREETWERKZ)
^^ thats tru i have 3 full sets of steelies ready for road time lol
Old Sep 6, 2007 | 01:22 PM
EFin' Kyle's Avatar
Default Re: 4x114 conversion (JKGONZALEZ3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">kyle, you may want to rethink the 4x114 swap.
4x100 FTW! everyone has a spare set of steelies in their backyard that they can loan ya. </TD></TR></TABLE> =P im going to get a set of 5 96' ITR wheels =P so i will have a 5th spare. becuz im awesome. hahahaha i dont know how often im going to be driving my crx anyway. im so afraid of theives i just wanna build her =D
Old Sep 6, 2007 | 01:27 PM
.Grimace's Avatar
footwork mastery
haha yes. get some old lady to pull over and you can jack her spare
Old Sep 6, 2007 | 06:47 PM
EFin' Kyle's Avatar
Default Re: 4x114 conversion (Gremice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gremice &raquo;</TD></TR><TR><TD CLASS="quote">
haha yes. get some old lady to pull over and you can jack her spare </TD></TR></TABLE> Stealing steelies FTW! hahaha
Modified by EFin' Kyle at 3:03 AM 9/25/2007
Old Sep 6, 2007 | 11:22 PM
CRX1.4DualCarb's Avatar
Just to understand something.
Rar trailling arms from integra will be a stringht bolt on job.
But how to change the front to 4x114 bolt pattern? Will the integra knucles fit with out any problems also?
Old Sep 7, 2007 | 09:38 AM
thevtecnician's Avatar
For the rear you use da teggy pads and calipers to replace them. and the front you use 90-91 civic ex pads and calipers.itreally depends on what knuckles you use. For the rotors you use non vtec preludes or redrilled integra ones.
Modified by thevtecnician at 10:58 AM 9/7/2007
Old Sep 29, 2007 | 06:14 PM
shininef's Avatar
Default Re: 4x114 conversion (thevtecnician)
great info
