dohc f22b performance parts
i recently had an f22b swaped into my car and i cant find any aftermarket parts for the motor any suggestions on a website? i was looking to find a supercharger or turbo kit for the car but can only find for the h22.
If you want a turbo the manifold from an F22A SOHC (90-93 Accords) will fit your F22B. Then it's a regular kit from then on.
Any H23A camshafts will work in the DOHC F22B.
Use B-series adjustable cam gears.
Whatever you do be sure to tune it.
You probably won't ever find a super charger for the nonVTEC engines. You could fit the H22 JRSC kit onto the JDM F22B with an intake manifold adapter plate but then again it's a supercharger, not a lot of gains to be had from it. Turbo would be cheaper.
Pirate
Pirate
doesn't the f22b have exactly the same head as the usdm h23? (correct me if i'm wrong)
in which case you can use an h23 turbo manifold, along with anything head related/that bolts to the head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin »</TD></TR><TR><TD CLASS="quote">doesn't the f22b have exactly the same head as the usdm h23? (correct me if i'm wrong)</TD></TR></TABLE>
It's not exactly the same, but it's 98% the same. The head casting is a little different where the head gasket meets the block. Anything that you can use for the H23/F22A will work on your DOHC F22B
preludeguy06
Sep 9, 2005 03:01 PM
