anyone know how to install ac compressor??
Old Aug 29, 2007 | 09:34 PM
melsun_ap1's Avatar
Default anyone know how to install ac compressor??
anyone know how to replace ac compressor on a 1996 honda accord? if u guys wanna know, its a 2.2 4 cyl. non vtec. thank you
Old Aug 29, 2007 | 11:41 PM
EFM_ookie's Avatar
Default Re: anyone know how to install ac compressor?? (melsun_ap1)
NO!!! this has never been done before! you are going to have to swap the whole motor!
Old Aug 30, 2007 | 12:10 AM
H22_aCCoRd_07's Avatar
Default Re: anyone know how to install ac compressor?? (EFM_ookie)
come on markus... give the guy a break...... ok to take off the a ac compressor you need to undo the two ac lines running to the ac compressor( its a 1 10mm on each one).....then you wanna loosen up the alternator belt by loosening up the alternator a little... then undo the four 10mm bolts that hold the ac compressor to the ac compressor bracket.....done
Old Aug 31, 2007 | 06:06 PM
melsun_ap1's Avatar
Default Re: anyone know how to install ac compressor?? (H22_aCCoRd_07)
thanks man i appreciate the help.
Old Aug 31, 2007 | 09:02 PM
melsun_ap1's Avatar
n also where do i pour the oil into?
Old Aug 31, 2007 | 09:04 PM
melsun_ap1's Avatar
n when im done is it a must i take it somewhere to get it recharged or cant i just recharge it with the cans from the store?
Old Sep 1, 2007 | 05:22 PM
JDM_Acccord's Avatar
you should have someone do it; however, it can be done on your own.
Old Sep 2, 2007 | 03:43 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: anyone know how to install ac compressor?? (JDM_Acccord)
you need a machine to trap the refrigerant, all i can say is if you don't even know how to remove the ac compressor HOw the HELL do you expect to know how to service an AC system LOL, Obviously you do not have manual to begin with and you need to do more homework. AND one last thing it is illegal to repair your AC system @ home as i said earlier unless you have that machine to trap the refrigarant
Old Sep 14, 2007 | 06:59 PM
melsun_ap1's Avatar
Default Re: anyone know how to install ac compressor?? (kidcool1977)
well thanks for ur advice. im done, i evacuated the system at work, replaced the compressor at home and brought it back in for recover and recharge
Davidss
Jul 16, 2009 05:51 AM
Burgess0909
Jun 30, 2007 12:08 PM
erikiksaz1
Sep 24, 2004 07:50 PM
