obd2 gsr swap into crx problem
Old Aug 29, 2007 | 09:15 PM
quick4thgen's Avatar
Default obd2 gsr swap into crx problem
91 dx crx alreaedy did mpfi swap, car ran great no codes no problems. came accros a full obd2 gsr swap, everything is done, i used a p06 chipped to p28, and rywire obd0 to obd 1 harness adapter, did the removal and rewire of the resistor box so now i use obd 1 injectors. car turns over but will not start. i checked for spark, its good, when i spray starting fluid into throttle body motor starts and runs great til it runs out, so that tells me no fuel. i am getting fuel to rail. it seems the injectors are not firing. i tried obd2 injectors and the same thing no start. does anyone knw what injectors i need. or have any ideas. and does anyone know where i can find a list of the numbers on honda injectors to cross reference what they are and what they are out of..
Old Aug 30, 2007 | 04:33 AM
white90rexsi's Avatar
Default Re: obd2 gsr swap into crx problem (quick4thgen)
You etheir have a wireing problem, or a problem inside your distributor. I had the same problem with my gsr swap and it was wireine
DiabolicDiablo
18
May 27, 2012 02:45 PM
96accordsir
16
Jan 11, 2009 08:51 PM
boost_guy
Jun 4, 2006 01:50 PM
Turbo_Mike
Feb 20, 2006 12:36 PM
jdm5ghb
Jul 31, 2004 08:40 PM
