PREP (Pressure Relief Engine Protection) spark plugs
Anyone heard of these or used them? Would these be good for a high CR before you are able to get a tune.
http://www.prepsparkplugs.com/detfix.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">Anyone heard of these or used them? Would these be good for a high CR before you are able to get a tune.
Those words should never be put in the same sentence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prep Spark Plugs »</TD></TR><TR><TD CLASS="quote">Unlike oxygen sensors and some knock sensors (which can only retard ignition timing for all cylinders equally), PREP Spark Plugs act on a cylinder-by-cylinder basis. If detonation only occurs in one cylinder, then only one PREP Spark Plug will vent. This makes identification of the detonating cylinder(s) an easy task.</TD></TR></TABLE>
Amazing! No need to tune your high compression or forced induction engine ever again!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
LOL...
They would blow the plug wires off in our motors anyway.
</TD></TR></TABLE>LOL...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 »</TD></TR><TR><TD CLASS="quote">They would blow the plug wires off in our motors anyway.</TD></TR></TABLE>
No problem! Just clamp the wires down with Prep's new Honda spark plug wire clamping kit! Only $49.95! And, as an added bonus, if you call within the next ten minutes they will throw in a Turbonator-free! Dyno proven to add 25 WHP to any motor
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
</TD></TR></TABLE> omg fukin peed my pants these are rediculous
im going to invent a piston that changes shape (dome levels) so you have super high comp untill boost comes in then they collapse down to a dish style .. all within .00001 ms
ohhh and maybe injectors that change size at different loads... or a crank that self lightens.... um **** i could go on for days .... im bored
</TD></TR></TABLE> omg fukin peed my pants these are rediculous im going to invent a piston that changes shape (dome levels) so you have super high comp untill boost comes in then they collapse down to a dish style .. all within .00001 ms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">that's the thing, im like 200 miles away from so. cal. tuners.</TD></TR></TABLE>
That's why they rent trailers....
