steering wheel removal
i just bought a 00 civic and the previous owner had the steering wheel completly off. about 45 degrees off when im driving straight the H is pointing to the left. can anyone provide me with a link? or info?
There are plastic plates that you can remove on either side on the steering wheel. Behind these plates you will find star-head screws and a few connectors. Use the supplied red SRS blockoff connector to block the airbag circuit and unscrew those bastards. Your airbag will come out now. After you have that out, it's a 17 or 19mm nut in the middle of your wheel.
Enjoy
Enjoy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH »</TD></TR><TR><TD CLASS="quote">make sure you disconnect your battery first or else your air bag light will be on forever</TD></TR></TABLE>
Not on an EG - don't know about an EK. Good advice, though
civicb16
12
Nov 10, 2004 04:23 PM
