*NEED SOME HELP ASAP*
Old Aug 29, 2007 | 08:16 PM
91ef8's Avatar
Default *NEED SOME HELP ASAP*
I have a stock 91 crx with the original engine and ecu...changed out the piston rings and put engine back together...now the engine idles great but when i rev the engine it will go to just about redline and then fall to 3500rpm and wont rev any higher while bogging out...anyone have an idea of what can be causing this?
Old Aug 29, 2007 | 08:39 PM
gnar kill's Avatar
Default Re: *NEED SOME HELP ASAP* (91ef8)
I am assuming you forgot to hook somehting back up right....we need a little more info. was it running before you rebuilt it? are you throwing any codes?
Old Aug 29, 2007 | 08:45 PM
91ef8's Avatar
yes the engine was running perfect before i took it apart...and no the ecu is not throwing out any codes...im stumped
Old Aug 29, 2007 | 09:11 PM
91ef8's Avatar
bump
Old Aug 30, 2007 | 12:09 PM
91ef8's Avatar
no one out there has had this same problem?
RyanG
May 30, 2008 09:35 PM
JUN.
Feb 20, 2008 10:08 PM
91ef8
Sep 4, 2007 05:20 AM
bchomka
Nov 7, 2004 06:40 PM
