Couple of strange sounds.
I drive a 2000 s2000 and every once and a while my car will make a grinding noise right when I start it, it last maybe 2-3 seconds then ends. It happens most often when I have driven 150 or more miles at one time, could this be my Timing chain tensioners.
Also in 3rd gear when I let off the gas at around 27-31 mph it makes a ton of noise and some vibration, 2nd gear will do the same thing but at a lower speed. Is this normal?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2kap1 »</TD></TR><TR><TD CLASS="quote">that is def the clutch! how many miles do you have on your s2k?</TD></TR></TABLE>
stick around and learn it's the auto tensioner
https://honda-tech.com/zerothread/2072353
23rd reply..... timing chain tensioner.. talk to that guy and see if his experience was the same as what you're going through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2kap1v2 »</TD></TR><TR><TD CLASS="quote">that is def the clutch! how many miles do you have on your s2k?</TD></TR></TABLE>
you are def wrong!
timing chain tensioner ftw
you are def wrong!
Ray2943
Honda S2000
18
Sep 23, 2005 06:23 AM
