d16a6 motor trans ecu. b18a motor trans ecu. 2 da interiors one black one tan. other misc ef and
Old Aug 29, 2007 | 07:43 PM
hybrid1990crx's Avatar
Default d16a6 motor trans ecu. b18a motor trans ecu. 2 da interiors one black one tan. other misc ef and
Im always willing to trade for other parts if I need them, so don't be afraid to ask!!!!
Shipping is NOT included in these prices. PM me or leave message for questions.
All interior parts are black/grey unless otherwise noted
All parts in working order unless otherwise noted.
paypal is the best way to pay me.
parts will more than likely be shipping on saturday mornings.
Stuff without pictures will be up later.
$225
I have a d16a6 that came out of my old hatch. I had sold the car and 2 months later the new owner asked me to do a swap for him and I bought the motor off him after. Motor put out around 190-200psi and max of 6% leakdown when it was in my hatch has about 150k on it. Clutch and flywheel are off because the motor is on a stand, but they will be included.
$100
91 civic si trans. Also came out of my old hatch. Drove great when I owned it, new owner complained of clunk during decell but I don't think it was the trans.
$60
pm6 ecu. works great.
$400
b18a1 - obd0. Ran great. Pulled from my Integra I hit a deer with last year. Has fairly new plugs, cap, and rotor. Exedy stage1 clutch still grabbed hard. About 160k on it. Ran great and drove for 2 months after hitting the deer so no worries there. Sorry I don't have compression #'s on it.
$125
90-91 LS trans. Worked great. No grinds even in upper rpm's.
$50
pr4 ecu. works great. came from a 91 so the baro sensor is inside it.
$50
pr4 ecu. works great. i believe its from a early 90 because it has no baro sensor inside of it and when in my 91 it through a baro code.
$50
90-91 LS trans case. both halfs. the bell housing side has a broken shift fork that the linkage bolts to. case half is good. needs bearings as well.
$50
90-91 LS diff, counter shaft, and input shaft with gears.
$25
d16a6 valve cover. bare metal.
Make offer
91 integra interior. Tan in color. Complete besides for dash and front seats. I have an idea for what I want if you want to take it all in one shot or just offer me for small things.
Make offer
91 integra inerior. Black in color. Everything you need to do a color change. Front seats do not match rear but both are black. Passenger door panel cloth is falling off.
Make offer
91 integra shell part out, front end damage. No exhaust, motor, linkage, trans, suspension, interior, brakes. Tell me what you need I'll give a price.
APC 9.3 MM spark plug wires - sold
d16a6 dizzy cap - $10
89 civic Si MPFI harness UNCUT - sold
LS tranny, all new bearings, 5th gear is locked out, something I messed up - SOLD
2 intake manifold gasekts - 15 each 1 b and 1 d
2 TB gasekts - $10 each 1 b and 1 d
90-91 fuse box - $25obo
90-91 fuel filter and lines - $15
Ebrake console - $15
Driver side headlight - $35
Passenger side civic OEM corner light - $6 for one $10 for both
Driver Side civic clear corner - $10
Driver side bumper light 90-91 civic - $10
BLUE crx dome lamp - $15
90-91 crx tails driver side is cracked - $50 obo for set
90-91 crx 1/4 panel molding - $15
civic/crx glove gox - no broken tabs - $30
Crx tail light covers (inside) - $10
civic/crx clock and heater vent - crack is circled - $20
passengerside OEM civic corner light - $6 each or $10 for set
battery box, DIRTY, no cracks never used! $20
OEM b16 down pipe, no major dents - $20
Crx/civic window crank rings - $10
civic under bodyplastics - $20
obd1 teggy map sensor - $20
Speaker - $15
speaker $15
speaker $15
2 MTX audio speakers - $35 NOT PICTURED AS OF NOW
6 puck clutch and pressure plate- cable B series - sold
Factory Shift **** - $5
MSD RPM switch - never used, given to for money owed - sold
drilled and slotted brake rotors - DID NOT FIT MY 91 CIVIC SI- i think they are for DA integras - sold
Reverse Switch, uncut harness - $18
Reverse Switch, cut - $7
88-91 civic rear trays, NO SPEAKERS. $25obo
4 OEM 89-91 crx struts - $40
2 90-91 (top) and 1 88-89 (bottom) map sensors - $20 each
88-91 D series shift linkage, NO stabalizer bar - $15
88-91 Ignition lock - never used- 2 keys, $20
Ignition Harness, 3 cut wires, not sure why - $15
Old Aug 30, 2007 | 03:36 AM
Default Re: d16a6 motor trans ecu. b18a motor trans ecu. 2 da interiors one black one tan. other misc ef
bump
Old Aug 30, 2007 | 09:31 AM
bump
Old Aug 30, 2007 | 12:51 PM
bump
Old Aug 31, 2007 | 04:11 AM
buy my stuff!
Old Aug 31, 2007 | 11:21 AM
bump
Old Sep 2, 2007 | 09:16 AM
RacerRex
Dec 10, 2006 12:39 AM
OnEBadAss91EfCiVicHaTcH
13
Jan 22, 2004 07:44 PM
JunCivic Hatch
Oct 16, 2001 09:41 AM
