weird start up problem? not starter!
Old Aug 29, 2007 | 06:47 PM
DC4 Rasta's Avatar
Default weird start up problem? not starter!
ok so i just put a b16 in my teg went to start it up and it started up fine. turned it off it would start back. but if i push start the car it starts up fine and drives fine without any problems just perfect. so i tought mayb the starter was messed up so i change it out. i get the same problem. when i turn the key i hear the starter spinning sometimes i even hear it grinding on the flywheel. so now im thinking either my flywheel is messed up or i installed both starters wrong which i doubt. is it possible to instal the starter to the teeth on the starter are hitting the teeth on the flywheel instead of the groves?
dmanfree
Jun 21, 2013 12:38 PM
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
DC4 Rasta
Aug 30, 2007 10:38 AM
DC4 Rasta
Aug 29, 2007 07:03 PM
RiCE On IcE 2
Apr 25, 2005 10:17 AM
