weird start up problem? not the starter!
Old Aug 29, 2007 | 06:38 PM
DC4 Rasta's Avatar
Default weird start up problem? not the starter!
ok so i just put a b16 in my teg went to start it up and it started up fine. turned it off it would start back. but if i push start the car it starts up fine and drives fine without any problems just perfect. so i tought mayb the starter was messed up so i change it out. i get the same problem. when i turn the key i hear the starter spinning sometimes i even hear it grinding on the flywheel. so now im thinking either my flywheel is messed up or i installed both starters wrong which i doubt. is it possible to instal the starter to the teeth on the starter are hitting the teeth on the flywheel instead of the groves?
Old Aug 30, 2007 | 09:43 AM
GSR-TRBO-DA's Avatar
Default Re: weird start up problem? not the starter! (DC4 Rasta)
did you replace the clutch or take off the flywheel when you put in the motor?
Old Aug 30, 2007 | 10:38 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4 Rasta &raquo;</TD></TR><TR><TD CLASS="quote">ok so i just put a b16 in my teg went to start it up and it started up fine. turned it off it would start back. but if i push start the car it starts up fine and drives fine without any problems just perfect. so i tought mayb the starter was messed up so i change it out. i get the same problem. when i turn the key i hear the starter spinning sometimes i even hear it grinding on the flywheel. so now im thinking either my flywheel is messed up or i installed both starters wrong which i doubt. is it possible to instal the starter to the teeth on the starter are hitting the teeth on the flywheel instead of the groves?</TD></TR></TABLE>
You check the flywheel before you put it in? (any teeth missing?)
You put the right starter in?
Ak_ef9
Jun 12, 2009 11:42 PM
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
DC4 Rasta
Aug 29, 2007 07:03 PM
DC4 Rasta
Aug 28, 2007 06:52 PM
