hey guys, new to ef's... i have a question about rear disc's.
Old Aug 29, 2007 | 06:30 PM
perseverance's Avatar
Default hey guys, new to ef's... i have a question about rear disc's.
ok guys, wassup? i'm new to the forum. i've been on the eg/ek portion of h-t for quite a while now. so yea, i have a nice,clean,90 ef hatch civic and it's pretty fast. i don't want to get into detail, but it's b-series and turbo. so yea, since it moves fast i need it to stop fast. I've owned an ek, then an eg... now this EF. On my eg... i did the rear disc conversion and i loved it. i didn't need to swap the front disc's since they were EX and were the same size as integra ls 94-01. I didn't change my brake booster or cylinder cause i didn't need to. I did change the propvalve to a Da propvalve.. i believe 35/40. On an ef, can i use rear disc's from An integra? what e-brake cables would i need? as far as front brakes, can i get them from an ls? i'm sure i'd need to change my propvalve.. but would i need to change the brakebooster and master cylinder>?remember, i want the best brake setup with oem stuff and want to stay 4x100. Thx for all the help in advance.. as soon as i get my car cleaned up, i'll get some pics. thx again guys.
Old Aug 29, 2007 | 07:22 PM
cb07's Avatar
The entire rear trailing arm/hub/brake assembly from 96-01 integras swap over to an EF.
Si Ef's had discs up front. Direct swap to your car.
Old Aug 29, 2007 | 08:34 PM
how about DA stuff? i can get da stuff from the junkyard pretty easy. can i just swap everything,front+back from a DA? what about the BB and MC? that needed? i'm sure propvalve is needed. and which e-brake cables?
Old Aug 29, 2007 | 08:41 PM
cb07's Avatar
I don't think the DA is a direct swap. There's a few 94-01 Teg's at You pull it out here though. If you want, I'll pull the parts for you if you pay for them + shipping.
I'm pretty sure the only bolt on direct swap is rears from a 2nd gen Integra, and the fronts from the Si EF. Pretty sure.
Old Aug 29, 2007 | 08:50 PM
nah, i can pull the self for myself. thx man. i just need to kno what to pull. i've done this on ek's and eg's.. just learning on ef now. thx again
Old Aug 30, 2007 | 04:55 AM
CRX Toad's Avatar
Default Re: hey guys, new to ef's... i have a question about rear disc's. (perseverance)
Being that you are new first off you need to check the FAQ https://honda-tech.com/zerothread/1508680 you would have had your answer much faster.
90-93 Integra trailing arms will fit no problems but you must use YOUR CARS control arms. You can also use 90-93 Booster and MC. You can use the front knuckles but must be lowered otherwise your camber will be off.
http://crf50.no-ip.com/fourthg....html
If you had used the FAQ you would have had your answer yesterday.
98gsr-808-91dx
Jan 15, 2010 03:36 PM
nickeynick
Dec 22, 2006 07:35 AM
1JDMDOMINICAN
Sep 29, 2005 06:54 AM
D-Man
15
Nov 9, 2001 06:27 PM
