Eg raditor and ef a/c fan question
will this work at all? i have a b series swap in my ef full race traction bars and full sized radiator too. The ac fan for the ef doesnt fit because i have a dc sport header. I came to a idea of using a eg half sized radiator and get 2 slim fal fan, one for the rad and other one for the a/c. i was planning to mount the slim fal fan for the a/c on to the consentor (sp?) and act like a pusher. will it work at all ?
Is there enough room to fit a slim fan in front of your header? I think that would be the easiest option. Usually people run the EG radiator in non-A/C setups; the extra fan is to help the cooling system due to the extra draw of the A/C compressor.
I think you can also use a slim fan set to push in front of the condensor if there's not enough room in front of the header. I think Wes V. has that setup.
you can use the EG radiator with the slim fan and you can mount the the slim fan either way to the condensor if your gonna keep A/C
I'd put mine in front behind the bumper cover cleaner and It'll hide it,But overall it should work...
Charlie Moua
Aug 27, 2007 03:39 PM
NinetyTwoHB
Feb 25, 2006 10:07 PM
rjay8604
18
Jun 26, 2005 12:44 AM
