98 Si Trans In 95 Honda Civic Dx Coupe I Was Told It Works?? True Or False??
pickin up a 5spd 98 civic tranny for my 95 coupe i was told it will work gettin a wicked deal on it so does this work true or false?? thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">I was gonna say no but I saw You lived in Canada so my answer is yes.
if im thinking about the same maine thing you are im laughing my *** off right now
gunna take tha cah to bah habah and buy sum beeah and lobstah
</TD></TR></TABLE>if im thinking about the same maine thing you are im laughing my *** off right now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_honda_man »</TD></TR><TR><TD CLASS="quote">lol
what is that supposed to mean HATERS!! ha ha jks
No hate, we just get confused because the Canadian Si model is our EX. If it was a USDM Si trans (B-series), it would not work on your motor (D-Series).
</TD></TR></TABLE>No hate, we just get confused because the Canadian Si model is our EX. If it was a USDM Si trans (B-series), it would not work on your motor (D-Series).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
Ha, I forgot about that, I was about to say "uhhh '98 si??"
@ OP:
Yeah, it'll work fine.
EDIT:
Not only will it work but it'll noticeably improve acceleration.
</TD></TR></TABLE>Ha, I forgot about that, I was about to say "uhhh '98 si??"
@ OP:
EDIT:
haha thanks guys yea i forgot the us models are a bit different one thing i dont get is my d15 trans has the speed sensor on top and the 98 trans doesnt? and can i use my flywheel with the 98 tranny or do i need a new flywheel??? thanks again guys!
thanks guys both tranny's are 5spds so perfect i can use my flywheel also the speed sensors are different the D15 trans has a 10MM bolt on each side and the 98 trans looks to only have one so i guess i need to go pick up a new sensor
your speed sensor will fit, yours only has one bolt holding it to the tranny as well (the two bolts you see only unbolt the top electronic part of the speed sensor)
O REALLY!? so it has 2 bolts for it but i can get away with only tightening the one?? is that what your saying?? sorry im slow with all these import combos and what works with what lol i came from bein a die-hard chevy guy to switchin over to havin good gas millage
no, it has one bolt just like the 98, the speed sensor can be taken apart and those other two bolts hold it together (you don't need to remove them) the bolt you need to remove is down lower and holds the metal part to the transmission
Luis78797
Mar 24, 2015 05:58 PM
j-rome
Mar 1, 2008 06:18 PM
iam7head
Feb 11, 2003 09:08 PM
