FOR SALE: 1998 Integra Type R #0055- HC H2/H3, PT, SCCA ITR prepped - MISSOURI
Old Aug 29, 2007 | 03:37 PM
mstewar's Avatar
Default FOR SALE: 1998 Integra Type R #0055- HC H2/H3, PT, SCCA ITR prepped - MISSOURI
1998 Acura Integra Type R #0055 - Championship White
-Clean title
-59,XXX original miles on the chassis
-Approximately 4,000 miles on the brand new B18C5 long block and transmission from American Honda.
-Current NASA Annual Logbook
-SCCA logbook (was not annually inspected this year though)
ENGINE/TRANS:
- Mugen Headgasket
- AEM Short ram intake
- DC JDM 4-1 Header
- SMSP race turndown exhaust (dumps prior to gas tank)
- ACT SS Clutch disk with Heavy Duty Pressure Plate
- Fidanza Flywheel
- A/C, Power steering removed (PS looped using Padawan kit)
- OEM Honda CTR N1 Enduro crank pulley
- Energy Suspension motor mount inserts
- Password JDM magnetic drain plug (oil & trans fluid)
- Fastline Oil Catch Can
- Fuel Sampling Port
- HONDATA S200
SUSPENSION & BRAKES
- PIC Select R3 Coilovers (12k front, 14k rear)
- OEM 1994 Honda Civic Si front sway bar
- Whiteline Adjustable rear sway bar
- Skunk2 front camber kit
- Stop Tech Steel braided brake lines
- Carbotech XP12 Front Brake Pads (never used)
- Cobalt Spec VR Front Brake Pads (used)
- OEM Master cylinder, OEM booster, lines, and all 4 OEM calipers replaced this past spring
BODY
- Mugen replica adjustable spoiler
- Slightly rolled rear fenders
- Spoon Replica Front lip (on car)
- Special Projects front airdam (not yet installed)
MISC
- Custom Roll Cage with Driver's Side NASCAR door bars. All stich welded plates at joints with body (no boxes). A VERY nice and expensive cage.
-SFI roll cage padding
- MOMO Start Seat w/ dual lock slider mount
- MOMOsteering wheel w/ splined quick release
- Wink 5 panel rearview mirror
- Ultra Lap XT Lap Timer w/ beacon
- AMB 12v wired transponder
- Firecharger AFFF fire suppression system (2.6L dual nozzle)
- Handheld halon extinguisher
- Longacre electrical kill switch
- GForce 6 pt cam lock harness
- Driver's side window net
- Inside Driver's side net
- 1 Set Kosei K1 15x7 +38 offset wheels - silver
- 225/45/15 Toyo RA1's with plenty of life left mounted on above
- 1 Set Rota Slipstream 15x6.5 +38 offset wheels - Championship White
- 205/50/15 Toyo RA1's with a few heat cycles left mounted on above
VIN and additional pictures available on request.
SOLD
Modified by mstewar at 2:51 PM 9/14/2007
Old Aug 30, 2007 | 07:23 AM
jgirard's Avatar
Default Re: FOR SALE: 1998 Integra Type R #0055- HC H2/H3, PT, SCCA ITR prepped - MISSOURI (mstewar)
Good luck Mark
Old Aug 30, 2007 | 08:40 AM
jonshonda's Avatar
Community Builder
Nice race car!!
Old Aug 30, 2007 | 10:57 AM
midwesta's Avatar
whats up mark? you done?
Modified by midwesta at 3:04 PM 9/3/2007
Old Sep 3, 2007 | 09:38 AM
mstewar's Avatar
ttt
Old Sep 3, 2007 | 09:46 AM
LUXXXX's Avatar
GL with the sale.. makes me wish ida picked up chris fries last year for half the price of this
Old Sep 3, 2007 | 08:35 PM
mstewar's Avatar
Default Re: FOR SALE: 1998 Integra Type R #0055- HC H2/H3, PT, SCCA ITR prepped - MISSOURI (LUXXXX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LUXXXX &raquo;</TD></TR><TR><TD CLASS="quote">GL with the sale.. makes me wish ida picked up chris fries last year for half the price of this </TD></TR></TABLE>
yeah.. his was inexpensive.. good luck on your sale as well!
mrrobertle113
May 31, 2015 05:45 AM
Yosshaa
Oct 27, 2009 03:35 PM
mstewar
Sep 7, 2007 01:18 PM
jam_itr
Feb 7, 2006 06:01 PM
riksride
Aug 1, 2002 09:47 AM
