low rpm studdering
my car has this weird low rpm studder problem thats been happening for awhile but is just now getting worse...i'll explain, the engine/chassis studder only accures between idle and about 2,500 rpms. during the studdering it looses power but once above 2,000-2,500 there is a sudden rush of power. above that it runs like a champ and is one of the fastest sohc in town. it also has a very erratic idle but only sometimes, usealy on really hot days. any suggestions? thanks guys
i know it might sound stupid, but check your torque mounts, if there the old stock ones when your at a low rpm it makes ur motor shake, then when u get on it it goes away , thats probaly your problem.
Hey there, i had a very similar problem with my 94 civic hatch that i just fixed recently. My problem was the idle control valve... it needed to be replaced. I would head to a local scrapyard and pick one up. It shouldn't cost more than $30. My civic would idling strangely at around 1500 rpm and than shoot up after that. Anyways, good luck !
by torque mounts do you mean engine mounts? and my idle problem isn't that bad, it doesn't have a really high idle it's actually really low and will glug off and on?
Word.
I am battling this same issue ( '99 civic EX ).
I've replaced motor mounts, dist. cap & rotor, spark plugs..
My electrical system also seems sort of weak in general. ( ie: at idle, headlights dim when utilizing the power steering or moving the power windows up/down )
Car drives kinda like **** 'till 3k rpm.
Quite a mystery.
Quite a mystery.
yep. I mean the motor is pretty much that way already.. but.. it's bad.
Actually today i cleaned and re-crimped my grounds with new terminals and had fantastic results. Soggy power windows even feel like they have a shitload of torque now. AC blows hard.. interior lights are brighter.. etc etc etc!
Under 3k is pretty good now and getting into gear is no longer such a pain.
I'll make a write-up if anyone's interested.
Blue-Civic-Hybrid
Dec 11, 2005 06:58 PM
Blue-Civic-Hybrid
Oct 4, 2003 09:04 PM
