Lets Play A Game...WTF IS WRONG HERE
Old Aug 29, 2007 | 12:21 PM
ExemptedNut's Avatar
Default Lets Play A Game...WTF IS WRONG HERE
So lets play a game where you guys help me determine whats wrong with this picture
I need some help
HINT: look at the wheels.
Old Aug 29, 2007 | 12:26 PM
SFlCrx's Avatar
Default Re: Lets Play A Game...WTF IS WRONG HERE (ExemptedNut)
looks like the caster is off maybe need a lca
Old Aug 29, 2007 | 12:27 PM
sirhavok's Avatar
you got the wrong axle on the car?
steering controll arm broke?
Old Aug 29, 2007 | 12:32 PM
think it could be the lca?
I bought the car this way about 8 months ago and it was just sitting, just started getting to it recently and didnt notice the wheel issue til after I lowered it and put the rims on. I dont think its the wrong axle but I suppose thats a possibilty...
any other ideas?
Old Aug 29, 2007 | 12:43 PM
jlicrx's Avatar
Default Re: (ExemptedNut)
may be the tie rods need adjusting - it has a lot of toe-out - is it the stock suspension?
Old Aug 29, 2007 | 12:59 PM
its just the front passenger wheel that seems to be out of whack.
it is stock suspension aside from coilovers sleeves I put on to see what kind of drop it would give
Old Aug 29, 2007 | 01:02 PM
89efDUSTY's Avatar
LOL just take for a free alignment check...problem solved.
Probably Tie rod GL
Old Aug 29, 2007 | 01:05 PM
jlicrx's Avatar
if it doesn't appear to have anything bent, like if it was hit hard on the passenger side, center up the steering wheel so that is half way between locked turning right and locked turning left - try adjusting the outer tie rod ends to straighten up the wheels
Old Aug 29, 2007 | 01:10 PM
My_EFsedan's Avatar
looks like my car right now. driver side wheel is straight and pass. points another way..i need alignment, might wanna get that checked.
Old Aug 29, 2007 | 01:44 PM
Disco Monkey's Avatar
Default Re: Lets Play A Game...WTF IS WRONG HERE (My_EFsedan)
it still has a d-series in it?
Old Aug 29, 2007 | 02:19 PM
peanut butter's Avatar
Default Re: Lets Play A Game...WTF IS WRONG HERE (Disco Monkey)
I don't think I have seen those little triangle pieces you have under the bumper mounts before.
Old Aug 29, 2007 | 02:38 PM
Scotland:EF3's Avatar
it lacks this thing called a front end lol.
not sure what to look for?
Old Aug 29, 2007 | 02:53 PM
jayturboef's Avatar
Default Re: (ProJect:EF3)
it has monster truck wheels on it..lol
Old Aug 29, 2007 | 05:07 PM
KrenzyRyan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExemptedNut &raquo;</TD></TR><TR><TD CLASS="quote">
HINT: look at the wheels. </TD></TR></TABLE>
I cant see the Wheels, only the tires
Old Aug 29, 2007 | 05:53 PM
alscrx's Avatar
Default Re: Lets Play A Game...WTF IS WRONG HERE (KrenzyRyan)
DEF an outer tie rod that needs to be adjusted. Was prob changed and not adjusted right. Just loosen the lock nut and turn it in lots more inward. You should compare it to the other side!!!
Old Aug 29, 2007 | 06:00 PM
90goldhatch's Avatar
Default Re: Lets Play A Game...WTF IS WRONG HERE (alscrx)
um oh i know your missing the whole front end i win
Old Aug 29, 2007 | 08:25 PM
Bob_760's Avatar
Default Re: Lets Play A Game...WTF IS WRONG HERE (peanut butter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peanut butter &raquo;</TD></TR><TR><TD CLASS="quote">I don't think I have seen those little triangle pieces you have under the bumper mounts before.</TD></TR></TABLE>
88-89 HF bumper support
Old Aug 29, 2007 | 09:22 PM
lol actually the whole front end is sitting in the garage with the car, but no thats not what is missing.
they do kinda look like monster trck tires but really they are only 16"
anyway, ill try adjusting the tie rods with the way that was previously suggested. Cross your fingers for me cause almost everything on this car is in terrible shape and doesnt work, so I'm hoping this fixes the issue
Old Aug 29, 2007 | 09:24 PM
Oh and yes, disco monkey, it still has a d-series which is definitely a problem planing on dohc zc motor
Old Aug 29, 2007 | 09:37 PM
crxforum's Avatar
You suck at drywalling?
CRX Forum
Old Aug 29, 2007 | 09:53 PM
Default Re: (crxforum)
haha, this is a garage at my apartment complex. I didnt drywall it
Old Aug 30, 2007 | 03:04 AM
denraweb's Avatar
Yup do the tie rod adjustment, eyeball it to get it straight enough, then drive it to a shop to get the alignment done...or do a DIY alignment, which sometimes yields better results than computerized alignment...most shops don't calibrate their computer often...and trust me it's nowhere near often...like every 10 years lol...
Old Aug 30, 2007 | 04:23 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExemptedNut &raquo;</TD></TR><TR><TD CLASS="quote">So lets play a game where you guys help me determine whats wrong with this picture
I need some help
[img]https://i4.photobucket.com/albums/y127/ExemptedNut/crxwheel.jpg[img]
Your core support looks like ****.
Good luck with the aligning.
Old Aug 30, 2007 | 08:52 AM
Yes my core support does look like ****! woohoo!
any more info on doing my own alignment?
Old Aug 30, 2007 | 11:22 PM
tnez's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">may be the tie rods need adjusting - it has a lot of toe-out - is it the stock suspension?</TD></TR></TABLE>
im with the noob, lol... looks like the toe alignment.
just take rear end photos and try to trade with someone over seas
...PROBLEM SOLVED!
Genesee99ex
Mar 13, 2010 10:37 PM
milkmanLCA
Feb 23, 2010 10:07 AM
alexsracing
Aug 5, 2005 08:15 AM
rondigs
Dec 15, 2003 02:25 PM
Spade
Jun 20, 2002 07:43 AM
