Power slot rotors
Old Aug 29, 2007 | 11:30 AM
jit01's Avatar
Default Power slot rotors
Hi I am going to get power slot rotors is there anything I need to change to have these put on or are they direct replacement of oem ? Also will they be fine with honda oem brake pads ?
I am going to get front and rear and change to ss brake lines later
http://www.prostreetonline.com...r.asp
I have a 95 del sol vtec with abs.
EDIT: or should I get brembo blanks ? oem replacement
Old Aug 29, 2007 | 11:34 AM
EL Vap133's Avatar
Default Re: Power slot rotors (jit01)
Brembo Blanks.
bmoua's Avatar
i'm using autozone rotors ($50) and hawk hps pads, stops pretty nice.
Old Aug 29, 2007 | 11:38 AM
jit01's Avatar
Default Re: (bmoua)
Brembo blanks would be better than those powerslots ?
Old Aug 29, 2007 | 11:40 AM
EL Vap133's Avatar
Default Re: (jit01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 &raquo;</TD></TR><TR><TD CLASS="quote">Brembo blanks would be better than those powerslots ? </TD></TR></TABLE>
IMO, yes.
Old Aug 29, 2007 | 11:42 AM
jit01's Avatar
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">IMO, yes. </TD></TR></TABLE>
Ok thanks I guess I will be getting those. They work fine with oem honda pads right ?
Old Aug 29, 2007 | 11:49 AM
Probot's Avatar
Default Re: (jit01)
they'll work just fine...but if you want to get better braking, upgrade your pads as well...Hawk HPS Street pads are pretty damn good
Old Aug 29, 2007 | 11:52 AM
jit01's Avatar
Default Re: (Probot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">they'll work just fine...but if you want to get better braking, upgrade your pads as well...Hawk HPS Street pads are pretty damn good</TD></TR></TABLE>
Ok thanks.
Old Aug 29, 2007 | 12:22 PM
Padawan's Avatar
Darth ModerVader
Default Re: (jit01)
It depends upon the deal you're getting, but honestly, AutoZone/Duralast rotors would work extremely well and cost even less. The Power Slot rotors would be fine too, particularly if you aren't tracking the car, but they certainly won't provide a performance benefit that justifies their cost. The only real benefit would be cosmetic.
glulude
May 14, 2007 01:27 PM
Dillon91Teg
Aug 17, 2006 05:01 PM
bigslimdog
Oct 26, 2005 09:34 AM
Accorddrver
Jul 24, 2003 05:32 PM
mattmw88
Mar 30, 2002 07:47 PM
