just put turbo cams in my built gsr wont idel need help!!
Old Aug 29, 2007 | 09:20 AM
98tegLSR's Avatar
Default just put turbo cams in my built gsr wont idel need help!!
i just put comp cams in my integra and now when i rev it and let the rpms drop it dies and at lights it will idel very low like 200 100 rpms then die out. i dont no what it can be i tried tighting the throttle cable but then the rpms will go down very slow. i didnt get it tuned yet with the cams i dont no if that can be a problem or not.
Old Aug 29, 2007 | 10:18 AM
Dartanian's Avatar
Default Re: just put turbo cams in my built gsr wont idel need help!! (98tegLSR)
You need to have it tuned.
Old Aug 29, 2007 | 10:39 AM
myfirstdc2's Avatar
did u adjust your valves when u put in the new cams?
Old Aug 29, 2007 | 10:40 AM
GSR in progress 96's Avatar
* B A N N E D *
Get it tuned. The tuner should know how to fix the idel.
Old Aug 29, 2007 | 10:42 AM
god of war's Avatar
advance the timing for now so that it will hold an idle, until you can get it tuned properly. it sounds like you timing is retarded a bit to much which would cause you to idle that low.
Old Aug 29, 2007 | 10:55 AM
Dartanian's Avatar
Default Re: (god of war)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by god of war &raquo;</TD></TR><TR><TD CLASS="quote">advance the timing for now so that it will hold an idle, until you can get it tuned properly. it sounds like you timing is retarded a bit to much which would cause you to idle that low.</TD></TR></TABLE>
Advance the timing on an untuned boosted car? That is ******* brilliant.
There is a lot more things that affect idle besides ignition timing.
Old Aug 29, 2007 | 01:27 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
Advance the timing on an untuned boosted car? That is ******* brilliant. </TD></TR></TABLE>
So is this topic made
If someone had a boosted car in the first place,
you should know if you put some bigger cams in, you would Need tuning.
Old Aug 29, 2007 | 01:34 PM
St Jimmy's Avatar
* B A N N E D *
There is a lot more things that affect idle besides ignition timing.</TD></TR></TABLE>
It might not be the greatest idea in the world but its alot better than "There is alot more things that it could be blah blah blah"
If your going to bash someone elses idea the least you could do is come up with your own... like maybe tune the car... How hard was that? And your questioning how brilliant someone else is?
Old Aug 29, 2007 | 01:48 PM
Dartanian's Avatar
Default Re: (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
If your going to bash someone elses idea the least you could do is come up with your own... like maybe tune the car... How hard was that? And your questioning how brilliant someone else is?</TD></TR></TABLE>
And your contributions have been phoenomenal. Get out of here noob.
revhardallday
Dec 13, 2008 01:08 PM
JCushing
11
Aug 22, 2005 04:48 PM
90HatchSTD
Jul 26, 2004 05:40 AM
LOWNSLOW
May 24, 2004 08:54 AM
