does anyones sunroof rattle?
Old Jun 14, 2002 | 10:23 AM
uneekcrx's Avatar
Default does anyones sunroof rattle?
i have an 88 crx si and the sunroof rattles like it's loose but i think the tracks are just worn out but everything is tight.....so does anyone else have this problem? if so how did you fix it? and where can i get instructions on how to disassemble the sunroof
Old Jun 14, 2002 | 12:37 PM
Malgerus's Avatar
Default Re: does anyones sunroof rattle? (uneekcrx)
Open your sunroof, look towards the rear of the sunroof, there are two plastic endcaps on the tracks, that you need to remove. two bolts (or nuts or something), then there are two bolts at the front of the sunroof, inside the track area, remove those, then the roof will slide backwards off the track, yank it out. take a looksie and try and spot the problem.
Old Jun 14, 2002 | 12:49 PM
mafioso102's Avatar
New User
after my swap, everything rattles in my car. damn hasport mounts
Old Jun 14, 2002 | 08:31 PM
Quik89Si's Avatar
Default Re: does anyones sunroof rattle? (mafioso102)
yeah my sunroof rattles...not much at all when it's closed but when it's open it's noticeable. Of course it's all rusted to **** - but that's another story for another time
Alex
Old Jun 14, 2002 | 08:45 PM
crxjdmsir's Avatar
Default Re: does anyones sunroof rattle? (Quik89Si)
I second that!!!!
iphatcrxi
Aug 29, 2006 05:30 PM
CLE
Feb 20, 2006 08:01 PM
gocivicgo
Jun 17, 2003 08:49 PM
jdm169
Mar 25, 2003 07:39 AM
speed_racer012
Feb 26, 2003 06:18 AM
