right side high beam issues
I just picked up a 98 Honda accord V6. Im having a problem with the high beam on the right side.
I changed the bulb and still, there is no light activity. Ive searched and some say that there is a fuse for each light. I have checked high and low and could not find anything like that.
I did however, find the relays under the hood and swaped them, still no workie.
I am pulling my hair out, the car will not pass safety unless this gets resolved.
Please help
Please help
if the low beam works than the fuse is ok,, if low does not work chk fuse under hood fuse # 43 20 amp,, if fuse is ok, there might be an open in the red/green wire from relay to head lite
chk to see if there is any power at red/green wire and ground at orange/white wire ,,
if you get both you got a bad bulb..
if not, like i said, could be a wiring issue
lowandloud
Feb 12, 2012 06:06 PM
