Plate Mounting Trouble
Old Aug 28, 2007 | 10:57 PM
mizzoEG's Avatar
Default Plate Mounting Trouble
Thanks for any help guys, much appreciated, i just got my plates in the mail the other day for my eg hatch and I realized previous owners F'ed the front and rear plate mounts.
For the front bumper there are factory holes which <U>are too far apart for the plate mounts, why?!?! and custom holes which are just too screwed up and wide open. </U>
and for the rear, which i am more worried about, <U>the two upper mounting threads are broken</U> and i tried opening the interior panel but there is no clearance. and the two bottom mountings for the rear plate are too wide for the plate holes, same situation as the front bumper..
Old Aug 29, 2007 | 12:30 AM
310Integra's Avatar
doesn't it mount on the stock holes? did the previous owner drill wrong? also theres some bolt retainer that have to go on there if you didn't already know.
Old Aug 29, 2007 | 12:49 AM
jtfc3s's Avatar
if you want you could just get a Lplate relocator kit for the front.
Old Aug 29, 2007 | 07:09 AM
themikewoo's Avatar
have you tried putting vicegrips on it and turning it out or not enough threads there?
Old Aug 29, 2007 | 07:28 PM
mizzoEG's Avatar
Default Re: Plate Mounting Trouble (mizzoEG)
ok nevermind the front plate.. i will drill new wholes or use wally-nuts..
<U>BUT WHAT CAN I DO WITH THE BACK!!??!?</U>
Old Aug 29, 2007 | 08:33 PM
gourley's Avatar
Just use self-tapping screws and screw it in, your gonna need a plate there all day everday, not like its a show car.
Old Aug 29, 2007 | 08:57 PM
mizzoEG's Avatar
Default Re: Plate Mounting Trouble (duheeat)
so i need to put new hole in the rear with a drill, you're saying?
i suppose i could, just wanted to know if there is any other cleaner method.
thanks alot though
Old Aug 29, 2007 | 09:45 PM
gourley's Avatar
no just goto homedepot and buy self tapping screws
Old Aug 29, 2007 | 09:57 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG &raquo;</TD></TR><TR><TD CLASS="quote">so i need to put new hole in the rear with a drill, you're saying?
thanks alot though</TD></TR></TABLE>
That section of your rear deck lid comes out...you should be able to handle it from there. As for the front, you can drill those "fucked up holes" a bit larger and insert some universal license plate mounting hardware in them. You can find these dark materials at any hardware or parts store.
Old Aug 30, 2007 | 12:38 AM
mizzoEG's Avatar
Default Re: Plate Mounting Trouble (Archidictus)
the section of the rear deck lid does not come out, it is all a whole. maybe you are thinking of eg coupes and sedans but it isn't the same as the hatch.
but thanks for everyones concern, i just drilled new holes and the plates are nicely evened and extra tight.
BJIntegra
Mar 13, 2010 05:57 PM
Mr Zown D16
12
Mar 26, 2009 04:26 AM
SlowPokeEg
11
Oct 12, 2007 07:29 PM
Jay J
Jun 11, 2006 07:55 AM
PilotForLife86
Sep 16, 2005 01:19 PM
