B16a CRX (obd1 running obd1 injectors) problem!
Old Aug 28, 2007 | 07:52 PM
bodiez's Avatar
Hit the floor!
Default B16a CRX (obd1 running obd1 injectors) problem!
This is a bit difficult, because my dad is troubleshooting our build and im in VA (hes in NJ) but ill try my best to relay the info.
We just swapped a b16a obd1 engine into a 1990 CRX DX. We got the rywire harness and everything, and the engine is turning over and there is spark but the injectors are not firing. He checked the fuel rail and fuel is getting there fine, but the injectors themselves are not functional. Could this have bearing on the TDC sensor or the crank sensor not being hooked up right? if so, where are those sensors on the engine so i can relay the info to my dad
Just need some ideas as to why the injectors arent firing. Thanks!
Old Aug 29, 2007 | 09:27 AM
bodiez's Avatar
Hit the floor!
Default Re: B16a CRX (obd1 running obd1 injectors) problem! (bodiez)
bump !!!
Old Aug 29, 2007 | 10:20 AM
hybrid1990crx's Avatar
Default Re: B16a CRX (bodiez)
are you getting a pulse signal to the injectors?
tps is on the throttle body.
i think the crank sensor is in the dizzy but im not 100% sure.
Old Aug 29, 2007 | 11:32 AM
zCivic's Avatar
Default Re: B16a CRX (hybrid1990crx)
Is it hot outside right now. Can you hear the fuel pump prime when you turn the key on (not cranking just on) When the Check engine light is on you can kind of hear the fuel pump then under the dash on the left kick panel you can hear the main relay click at the exact moment the engine light goes off. If you can't hear the pump or the relay click try a different relay. Next I would ask are you using the resistor box. If so you need to remove it and connect the 5 wires. OBD1 injectors do not use the resistor box.
Old Aug 29, 2007 | 01:00 PM
bodiez's Avatar
Hit the floor!
Default Re: B16a CRX (zCivic)
i am not using the resistor box. thanks so far guys, ill relay this stuff to my dad. any other tips would be excellent
Old Aug 29, 2007 | 04:05 PM
zCivic's Avatar
Ok your not using the resistor box. Have him check to see if getting 12+v to the yellow/black or red/black wires depending on what the injectors clips came from. With Key on there needs to be 12v on one wire at all times. If not 12v check to see if there is 12v on the IACV on the back of manifold.
Old Aug 29, 2007 | 08:11 PM
bodiez's Avatar
Hit the floor!
He just measured the injectors and said there was around 5 volts to the injectors. So its the IACV ya think? what else should i look for that would cause that 5 volt
Old Aug 30, 2007 | 04:00 AM
quick4thgen's Avatar
i have the same problem but im using obd2 gsr in 91 crs si. i am using obd1 injectors and clips. with a rywire obd0-obd1 harness adapter to a chipped p28, i have not yet checked the iacv. what is the fix for this.
Old Aug 30, 2007 | 04:04 AM
oh and if i spray starter fluid in it its starts right up and will run as long as i spray.
Old Aug 30, 2007 | 04:20 AM
white90rexsi's Avatar
Default Re: B16a CRX (quick4thgen)
I had the exact same problem with my obd1 gsr in my crx. I have the rywire converted engine harness with a locash racing ecu adapter. A few of the distributior wires where swaped ( due to locash and rywire using diffrent ways then eachother). I changed them and it started right up! Also If something inside you dizzy is not right that could prevent the ecu from spraying the injectors.
Old Aug 30, 2007 | 08:46 AM
bodiez's Avatar
Hit the floor!
RESOLVED!
One of the connectors was not hooked up right. Was a ground for the thermostat which is also a main ground for the dizzy. Connected it and it fired up for the first time
Thanks guys!
Old Aug 30, 2007 | 04:23 PM
zCivic's Avatar
Good deal. Glad it started. I was saying check the IACV for 12 volts because it shares the same positive signal from the ECU. If you have 12 volts there and not to the injectors something is wrong in the wiring.
MastaFlyMason
Sep 3, 2017 10:06 AM
shaylude01
21
Jan 30, 2012 09:07 AM
Adi_King
27
Apr 6, 2010 07:49 PM
contentious
11
Oct 28, 2005 12:04 PM
