code 8, 4
Old Aug 28, 2007 | 06:06 PM
91H4hatch's Avatar
Default code 8, 4??
Iv had my swap for a year now and everything has ran great. ZC swap in a 91 Hatch. Today it pretty much would not run. Code 8 TDC, and code 4 Crank angle sensor. When i did the swap, i had a wire backwards and it threw the same code. Now it's doing it again. Should i just replace the two sensors? Or could it be something else?
Old Aug 29, 2007 | 10:39 AM
91H4hatch's Avatar
Default Re: code 8, 4?? (91H4hatch)
bump
Old Aug 29, 2007 | 10:41 AM
89s1's Avatar
I had a code 8 from running a bad dizzy, if you've got a friend that can lend you a dizzy for a half hour I'd try that first.
Old Aug 29, 2007 | 08:27 PM
91H4hatch's Avatar
Default Re: code 8, 4?? (89s1)
It was my dizzy wiring. I did kind of a half *** job the first time. Got er' done right now. Runs like a champ!!
Old Aug 29, 2007 | 10:06 PM
89s1's Avatar
what was wrong with the wiring, just in case a guy searching comes upon this
Old Aug 29, 2007 | 11:34 PM
EFM_ookie's Avatar
wire prob came loose. solderin and shrink wrap ownz you!
Old Sep 1, 2007 | 06:38 AM
91H4hatch's Avatar
There was a couple loose connectors. nice connectors and heat-shrink did the trick
Old Sep 1, 2007 | 07:06 AM
EFM_ookie's Avatar
91shownogo
Jun 22, 2011 06:22 PM
mike9571
Jul 9, 2007 09:05 AM
1_SC_GSR
Aug 14, 2006 10:24 PM
Rukusmasta2
Mar 4, 2006 09:21 AM
